6th May 2013, 06:59 PM
tacho accuracy
my tacho seems to be reading alot lower rpms than what it sounds like to my ear, at idle it reads 600rpm but sounds mor like 800-900 and when driving 2500rpm sounds closer to 3000rpm.. is there anyway i can check the rpm without buying a new tachometer?
6th May 2013 06:59 PM
7th May 2013, 06:54 AM
Patrol Freak
Should be around 2000ish at 60km/h depending on your tyres.
Regards,
Eric.
Sent from my iPhone 5 using Tapatalk
1998 GU RD28T: RIP
1996 GQ RD28T: RIP 11 days later
Hello 2012 GU CRDZD30
Nissan winchbar + Warn, Dual Battery/Redarc, UHF and Titan rear drawers
7th May 2013, 07:17 AM
SUCH IS LIFE
I would say it will depend on the vehicle you have, tyres you have, diff ratios, etc..
But if you just think it sounds different then I reckon you could borrow another tacho and check or get a scangauge or similar to check or hook it up to a consult system to check.
________________________
______ 2017 D-Max _______
7th May 2013, 01:53 PM
Patrol Freak
Guess you could work it out with a gps? Speed travelling and what the tacho reads, then use your diff ratios etc
Pretty sure I saw a website somewhere that had all the formulas to work it out.
Regards,
Eric.
1998 GU RD28T: RIP
6th September 2013, 02:43 AM
600 would be quite recognizable, but I do not see exactly why you should worry over the meter if the sound is fine?
6th September 2013, 02:45 AM
Altough, the glow system for a diesel would be wired such to stop at more then 2400 revs (or so). You could try to listen to the relay when hitting more then 2400 revs?
