6th May 2013, 10:38 PM
Moderator
nissannewby
And it does. But running big Tyres and heavy springs you not gonna get a harsh ride anyway. Go and jump it and see what happens when you use the shocks as bump stops.
You'll only do it once! Lol
Check out my Toy -->
Rogue Dung Beetle
6th May 2013 10:38 PM
7th May 2013, 01:05 AM
So whats the longest shocks that you can use with a 2" lift ???
7th May 2013, 02:31 AM
Take your measurements at full bump and full droop and go from there if you want more than coil drop outs, bump mods will most likely be required.
7th May 2013, 09:25 AM
So in a nut shell you buy springs first take your measurements then buy shocks??
7th May 2013, 11:46 AM
I have 5' snake racing coils and 14' travel pro comp shocks. I suppose up travel doesnt bother me because of the lift but with a 2' you would notice. You can always lower you rear shock mount for more up travel but then again thats less lower. I have drop out cones and retainers and i still need to weld an extension on the cone to stop the spring coming out. If i was you i would just grab 4 inch shock and figure it out. Extend your bumpstops so they hit before the shock bottoms out too
The Following User Says Thank You to Frontbumfab For This Useful Post:
BigRAWesty (7th May 2013)
7th May 2013, 04:55 PM
what do you guys rekon about putting 4" shocks in with 2" springs then ?
7th May 2013, 06:24 PM
#17
I know the 3 inch flexi coils can be safely matched with 6 inch shocks.
Tappin trolls
Brendan
If you're following this Patrol, Stop... You're not gonna make it
