Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Longest shocks possible with a 2" lift ?
    330 Post(s)
    And it does. But running big Tyres and heavy springs you not gonna get a harsh ride anyway. Go and jump it and see what happens when you use the shocks as bump stops.
    You'll only do it once! Lol
    Legendary Alitis007's Avatar
    15 Post(s)
    So whats the longest shocks that you can use with a 2" lift ???
  4. #13
    North brissy
    Take your measurements at full bump and full droop and go from there if you want more than coil drop outs, bump mods will most likely be required.
  5. #14
    15 Post(s)
    So in a nut shell you buy springs first take your measurements then buy shocks??
  6. #15
    Expert Frontbumfab's Avatar
    I have 5' snake racing coils and 14' travel pro comp shocks. I suppose up travel doesnt bother me because of the lift but with a 2' you would notice. You can always lower you rear shock mount for more up travel but then again thats less lower. I have drop out cones and retainers and i still need to weld an extension on the cone to stop the spring coming out. If i was you i would just grab 4 inch shock and figure it out. Extend your bumpstops so they hit before the shock bottoms out too
  7. The Following User Says Thank You to Frontbumfab For This Useful Post:
    BigRAWesty (7th May 2013)
  8. #16
    Apr 2013
    what do you guys rekon about putting 4" shocks in with 2" springs then ?
  9. #17
    Expert Brendan56's Avatar
    Townsville
    I know the 3 inch flexi coils can be safely matched with 6 inch shocks.
    Tappin trolls
    Brendan
    If you're following this Patrol, Stop... You're not gonna make it
