3rd May 2013, 10:18 PM
thanks darren ill let him know. lol we dont even have jaycar around here but there is a little electronics shop that i think is a jaycar dealer, it should work
Hello from Under Down Under!
3rd May 2013 10:18 PM
3rd May 2013, 10:21 PM
Moderator
I ground the edges of the box off to open the sealed box and then taped it up when I was done. He has nothing to loose, it's knackered so,open it up before he takes it to the guy. Jaycar is neither here or there, the electronics old school bloke is your man mate.
Good luck
Check out my Toy -->
Rogue Dung Beetle
3rd May 2013, 10:29 PM
Rotaredom
Tell him to take a pic of it and send it to you so we know what your / he is actually talking about Lucas.
But yeh as Darren said an old skooooool electronics bloke might be able to fix it cheaply
4th May 2013, 09:36 AM
What is the problem with his old one?. They do suffer from dry solder joints.
After you open it up have a look at the connections on the printed circuit board, even run a hot soldering iron over all of them.
Mid 90 model Skylines use the same control module.
The Following 2 Users Say Thank You to Yendor For This Useful Post:
MudRunnerTD (4th May 2013), taslucas (4th May 2013)
4th May 2013, 09:57 AM
Thanks heaps rod, I only have vague details as to why he wants a new one. I'll pass that on cheers. Probably get hold of a skyline one easier if he actually needs a new one.
FanTapstic!
24th May 2013, 03:01 PM
How'd you go with this? If you cracked it open post pic's of the circuit board. All the other boards I've seen in my GQ are really easy to diagnose problems and work on.
GQ Safari 2.8TD. BFG AT's / Safari Snorkel / Straight thru exhaust / Lots of electrical mods
