29th April 2013, 10:46 PM
#11
Advanced senility
taslucas
Please explain??
FanTapstic!
just presuming that it is a TD42, on the right hand side where the oil filters screw onto, that alloy housing hides the oil cooler. undo the bolts etc , remove the cover and you will find a miniature radiator, that is the oil cooler
Buggered up, should have had the two quotes on here, ah well !
The mind is still making contracts that the wallet can't afford
1993 Maverick TD 42 mit einem Turbolader, triple battery setup with 2 twin battery units & solar panel, 21/2 & 3 in exhaust, 5 dash mounted gauges, 55 ltr beier frig/freezer, broken winch, UHF & HF radios hf auto antenna, rooftop tent, portable satellite tv system and the ship hanging on the back [4.2 m runabout with 50 johnson]
happy hour
Dakabin 4503 QLD
WARNING: Towballs used for recoveries,can and do kill people and damage property and also scare the shit out of people standing next to the car
The Following User Says Thank You to Brisat For This Useful Post:
taslucas (29th April 2013)
29th April 2013 10:46 PM
29th April 2013, 10:49 PM
#12
Advanced senility
Stropp
sounds like a cracked head!
How is the engine oil going to get into the water ??
happy hour
Dakabin 4503 QLD
29th April 2013, 10:57 PM
#13
Advanced senility
Kelvinator
Stop driving it, first of all. And if you are not mechanically inclined, as it would sound, take it to a mechanic. Oil in your water is BAD. Either head gasket or cracked head or cracked block into water gallery, either way its going to be expensive. Unless, and this might be crazy, somebody put the oil in the radiator instead of the motor. I've seen some funny things in my time.
How would the oil get into the water, head gasket usually will let go between the cylinders or into the water gallery, oil cant get into water from a cracked head or a cracked block normally. If it was that bad it would have had to been farking hot so there would be lots more things to worry about
happy hour
Dakabin 4503 QLD
