Good to see on of us is getting off our bums and doing this..
I was looking at itcthe other day and instead of going off the 4 6mm screw for the handles, I was thinking a frame from 3rd row seat belt tops to 2nd row seat belts. And the put the shelf where you like. I think it'll be a lot stronger this way compared to the 4 screws..
Bit of an up date, its about 1200 wide by 650 deep and will hang down about 200mm More if I can get some one to hold while I measure.
But sadly that wont happen. Going to have plexi glass walls screwed to some 12mm round with tabs for clear. Front panel not sure yet ,
if I'll just use a small gate closer or some spring loaded hinges I have from "Q"mart. Getting there,
Also only using off cuts from my roof rack, so Its basically free.
@ Kallen Already use the third row seat bolt holes as my spare is mounted internally.
Gday, just wondering mate, what did you use to fix roof rack to bars? Rekon they look like Rhino bars same as mine. I used cpl of steel galved stilidge bases for platform and hold em on with s/s truck hose clamps. Just dunnit to hold my craypots, obviously I rachet strap all to the bars
