25th April 2013, 06:58 PM
How to remove Manual Gearbox from 1998 GU Patrol
Hello All,
We are trying to replace the clutch on a 1998 GU Patrol .. have removed all Gearbox bolts, starter motor etc .. but cannot pull the gearbox away from the motor, its stuck hard.
Any help on how to remove the gearbox will be appreciated.
Thanks,
Greg
25th April 2013 06:58 PM
25th April 2013, 08:43 PM
I think that there are two bolts at the top which you need to get undone.
Did you get these ones?
Mic
The Following User Says Thank You to happygu For This Useful Post:
Tigergk (26th April 2013)
25th April 2013, 08:52 PM
Nasty Dog - Moderator
It is always a good idea to post up an introduction before asking for any assistance Greg, just gets everyone on side from the start. http://www.nissanpatrol.com.au/forum...-Introductions
If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
The Following User Says Thank You to Woof For This Useful Post:
26th April 2013, 08:02 AM
Thanks Dogman, I've done the intro, looks like there are plenty of good resources here .. cheers
26th April 2013, 08:06 AM
Thanks Mic .. my son is trying to get it out and says he got the 2 on top but it wont budge .. I've been searching the net and have seen posts where they say the gearbox needs to be rotated to get it out .. we really have no idea ..
26th April 2013, 08:09 AM
The Following User Says Thank You to Bloodyaussie For This Useful Post:
26th April 2013, 08:29 AM
You need to rotate the gearbox clockwise about 30 - 40 degrees once you have separated the bell housing from the block. There are also 2 dowl pins that you will find are going to be a pain when re-installing.
The Following User Says Thank You to Alitis007 For This Useful Post:
