26th April 2013, 08:11 AM
#11
patrol2.8
Vibrates without brakes starts as soon as i take my foot off the go pedal the wheel bearings seem ok and doesnt seem to be any play in uni joints could it be the clutch its started slipping
If it's doing it when you back off the throttle without braking then id say uni's are a definite.
I just had my uni joints changed. There was no movement in them but they were stuffed. They go stiff for a while before the flog out and feel loose.
FanTapstic!
Hello from Under Down Under!
The Following User Says Thank You to taslucas For This Useful Post:
patrol2.8 (26th April 2013)
26th April 2013 08:11 AM
26th April 2013, 09:27 PM
#12
Thanks Tas will check it out when i get the car back did a trip along the border track a couple of weeks ago and ti took its toll on the car have had to do the hubs as they came loose broke a sway bar bracket and now the clutch has started slipping
Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
WARNING: Towballs used for recoveries,can and do kill people and damage property
5th May 2013, 11:05 PM
#13
well its not the uni`s will look at the brakes and engine mounts next will also be upgrading to heavy duty panhards etc over the next few months thinking could be the brakes i did throw in new pads on the front about 6 months ago swapped them on a trip so didnt get the discs machined if its that will most likely do a brake upgrade aswell
6th May 2013, 11:22 AM
#14
Those disc's will surprise you how they can be the root of problems.
1999 GU 4500 dual fuel
Il dado è tratto
12th May 2013, 11:03 PM
#15
so had it looked at and thier saying tie rods are worn so will replace them this week
13th May 2013, 12:03 AM
#16
can you feel it through the steering wheel and or what makes you say its in the front end and what sort of rims do you have ie steel or alloys
07 crd,,bridgestone 697lt, 2.75 buedesert ex,
SOLD theres a lot of my blood, sweat and money in that troll.
92 gq ti tb42efi my brothers gq extractors dual batteries brake controller uhf alloy bullbar
SOLD with a heavy heart but gone to a nice young fella
13 y62 the beast that burbles
20th May 2013, 07:58 AM
#17
Cant feel it through the steering ive managed to quiet it down by replacing the tierods behind the front diff and have just orderd a H/d adjustable front draglink as both both units had/have movement in them will be replacing panhards with H/D items over the next couple of months had the discs looked at and there all ok but will replace with upgraded units eventually im probably going about this all wrong and replacing things that dont need to be but these have been on the car since new and are showing signs of wear n tear and i look at it this way at least im building a collection of useable spares lol
4th June 2013, 09:39 PM
#18
Clutch or Uni's would be my guess.
4th June 2013, 10:18 PM
#19
im up for a guess at a rear buckled rim or 2
5th June 2013, 10:07 AM
#20
Does it only do it in 4wd? If so, and it isn't any of the other suggestions, maybe front cv joints or even diff gears are chewed out on the rear of the teeth.
If not only in 4wd, is it only noticeable in certain gears? I had the countershaft bearing fail in mine and caused a vibration and noise throughout the whole car (not just the front end).
Otherwise, check the uni joints and wheel bearings, just work with process of elimination and it shouldn't be too hard to find.
1998 GU Wagon, RD28ETI, Custom Exhaust, Chipped, Go Baby Go Switch, No plans to swap it.
