25th April 2013, 09:29 AM
#21
Hardcore
Is that for a 5 pin rocker switch? Or 3 pin?
IF ITS NOT BROKEN IT MUST BE A PATROL
25th April 2013 09:29 AM
25th April 2013, 09:38 AM
#22
Moderator
healy
5 pin ARB style Carling switch. I have read that some carling switches are different so make sure but that works for ARB carlings.
Check out my Toy -->
Rogue Dung Beetle
7th May 2013, 06:48 PM
#23
How do you remove the blanking panels for switches (the one under the a/c panel) without damaging them? Have tried today but got a little frustrated and gave up!
7th May 2013, 07:49 PM
#24
There is no switches under the a/c panel. Just a ciggie socket. The panel in the centre console hss screws behind it. Yoy need to remove the whole console to do this.
I tapped that app...
7th May 2013, 09:06 PM
#25
To the left of the ciggy sockets ahi have the sub tank switch and the rear a/c switch. I have a GU 7 if that matters.
7th May 2013, 09:10 PM
#26
Moderator
Mentok
You need to remove the gear stick surround. Screw under the ashtray. Once removed there a two screws for you to undo and the whole panel will come out easily
Rogue Dung Beetle
7th May 2013, 09:16 PM
#27
Mentok
Ahh that explains it. Listen to MR then.
#28
MudRunnerTD
Thanks MudRunnerTD. Will try that tomorrow.
