19th April 2013, 01:24 PM
Using original CD stacker with aftermarket stereo?
Hi All,
I'm looking at upgrading the stereo unit in my 98 GU Ti and would like to continue to use the original CD stacker.
I haven't purchased a new unit yet or removed the original to have a look at the connections but was wondering if anyone else has been down this road before and whether it's possible.
19th April 2013 01:24 PM
19th April 2013, 01:29 PM
a member of the menagerie
I couldn't see why you couldn't do it,
The only thing that I would think of is you might need to find out what brand the original stacker and stereo is ie: Pioneer, Sony etc
As you might need to purchase the same brand of head unit so it controls the stacker.
I am sure someone here should be able to point you in the right direction, good luck with it,
Mark
Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
19th April 2013, 08:49 PM
20th April 2013, 01:05 AM
get a unit with a usb port then put all your tunes onto it in mp3 mode
can put 50 + albums on it or a socket for a mps player
this is what i have
sockets ar on the rh side
OH LEATHER IS NICE
20th April 2013, 04:17 PM
Yeah, was also thinking about what I could use the space for if I can't use the stacker.
Thanks for the replies guys.
21st April 2013, 12:02 AM
The Mad Ozzy
you can always fill the void with a pocket or fill auto gauges.
As MC97GQ has mentioned, to use the stacker with an after amrket head unit, you will need to ensure it is compatible. It will be a cheaper option to rip the lot out and go with a unit with a USB input and use a slim USB stick full of songs. I have a USB stick that is about 12mm long and hold 16gb worth of tunes that I picked up from Dick Smith for around $30, best part is that because is it is small, won't get knocked about or damaged by people reaching for the controls or other items nearby
www.swat4x4.com
21st April 2013, 09:12 AM
Thanks Fellas,
If I go the MP3 option at least I won't have problems with tracks skipping while on rough surfaces.
Problem solved!
