18th January 2013, 11:16 AM
Overheating while the aircon is on????
Guys I got a problem...
On a hot day I like to be comfy I'm not the sort of bloke that likes my boys swimming in soup, so I like to turn on the air-con, I only have 1 small drama.
Every time I turn it on my bloody troll over heats, I replaced the water pump about 2 months ago so it cant be that, and refilled the radiator with good coolant so I'm a bit perplexed as to what it could be.
Can anybody help this Melbourne heat is killing me!!!
Reason: typo
GQ patrol TB42 bog stock at the moment but working some wicked mods
Just a bloke trying to live 1 track at a time
18th January 2013 11:16 AM
18th January 2013, 11:23 AM
Hi matty - not sure what you drive but if you have a variable fan that comes on controlled by a thermostat that could be the issue? When you turn the car on does the radiator fan run all the time? If not does it cycle on when it heats up? Also - I believe it should also come on when the air-con is turned on. If not that perhaps your radiator needs a flush as well?
There's a number of things it could be - does it only overheat when the air-con is on - or does it run pretty hot normally?
Jas
__________________________________________
Roads? Where we're going we don't need roads.......
2012 Silver GU 8. Bullbar, Warn XD9000 winch, snorkel, towbar, roof bars and rack, awning, 33" Mickey Thompson ATZ 4ribs, 2" lift - Dobinsons coils and Koni shocks, more to come......
2013 Travelling Wilbury's Cape York Trip - bring it on!
Hi Matty , does your electic fan kick in when you turn on the AC regards Alex
18th January 2013, 11:40 AM
Sorry i should have been clearer. I drive a 1994 tb42 GQ there is only a single fan that runs all the time it usually runs about half way temp wise and and only ventures above that on really hot days( 35 degrees+) but not by much.
I never let it get too hot but the temp does climb only while the air-con is running and as soon as i turn it off it cools down again after about 10 minutes of driving.
Its really weird
18th January 2013, 12:01 PM
does your car have a electric fan for AC condessor and if so does it turn on when you put on the AC regards Alex
18th January 2013, 12:10 PM
I couldn't tell ya to be honest Alex sorry
18th January 2013, 12:18 PM
matty_3977
That's something you need to tell us though mate.
18th January 2013, 12:23 PM
Hey mate - do you have one or two fans near the radiator? That will tell you.
Jas
18th January 2013, 12:59 PM
I know it is something you guys need to know but although i know a little bit about engines I'm not that knowledgeable if it helps my only has 1 fan up at the radiator. I'm sorry I cant be of more help and I am thankful for the help I have got off all of you. But if you wanna push the subject tell me what it looks like and where it is and I can tell you if it is there or not.
mudski
18th January 2013, 01:07 PM
a member of the menagerie
Matty,
Look between the grill and the front of the radiator panel, there should be what looks like a small radiator and it could/should have a small thermo fan on it.
Mark
Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
