Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: My Draw Build
    43 Post(s)
    My Draw Build
    Well for some time now we've been wanting a draw system for the back of the Q. Buying a pre made one was out of the question, especially as the father in-law is a carpenter...
    So after a bit of looking, we settled on a design and away we go..
    Everything is glues and screwed. All holes pre drilled with a counter sinking bit attached, and good quality treated screws used so they don't rust..
    First up, 3 sheets of 12mm ply.. All you need. any bigger just adds unwanted weight...
    So we used a table saw to ensure all was nice and square.
    To start, you need a box...
    Next step is to frame the top in. This gives a bit extra strength, gives the draws something decent to lever against when out, and allows a lot more area to hold the top sheets down.
    next up the draw runners. Instead of using expensive and heavy ball bearing runners, we've use a product called UHMW. its a very tough, hard wearing nylon which slides like butter on each other when loaded.. Each piece is 8mm wide x 3mm thick.
    Next up a fitting and marking of the points to secure to the car. I've used the 2 seat belt points and 2 of the many tie down bolt holes in the rear..
    5mm plate for the seat belt bolts, bolted to the box using counter sunk bolts from the inside, and a 5mm plate with counter sunk bolt for the rear points.
    Next up are the wings. Once the box is secured in the center the winglets can be made to finish the face off. Quite simply a bit of off cut screwed on...
    Still plenty of room to access the jack
    Once happy meassure up the boxes and go nuts. I haven't got any pics as the father in-law smashed these while i was on shift one night..
    I can tell you the draws are 550 wide, 900 long, pantry is 280 deep, recovery draw is 210 deep and pull out bench is 50 thick.
    So there now painted..
    (excuse the father in-laws swearing)
    The white draw above is the pantry.. have painted it white inside and will be clear coating it to make messes easier to clean. And it feels cleaner being white..
    The thin one is the pull out bench, this will have a sheet of laminex vinal (kitchen bench top stuff) glued to the top for food prep.
  2. The Following 9 Users Say Thank You to BigRAWesty For This Useful Post:
    Alitis007 (15th April 2013), andrewh (15th April 2013), cgm (15th April 2013), driftoz (8th March 2020), Luke.C (21st July 2014), menace 2 (16th May 2014), mudnut (10th August 2013), oncedisturbed (17th April 2013), phtest (15th September 2014)
    43 Post(s)
    Well had a win today...
    Carpet is done and marble bench top done.. I removed the speakers, and rear seat belts and recovered all the pannels with the same carpet.. looks smik.. all that's left to do its add some rubber trim to the door cover edges, cargo barrier, led lights, draw handles paint the few bare edges..
    24/4/14
    We were packing for our first shake down trip. No fridge slide but we usually put the fridge in the camper anyhow.
    Handles arrived and they look good imo. They are a lip style grip. Something a little different.
    I've also added a cig plug for the fridge half way down the left hand side.
    And I've added a partition in the front of the pantry draw for plates and cutlery.
    As mentioned the cargo barrier is in.
    To secure it to the ply I have 6 bolts holding it to the ply, with the outer 2 secured to a strap returning to the rear seatbelt bolts.
    And the top is secured back to the gezzes Crist handles (technical term that is.. .)
    The final weigh in of the complete draws (not including barrier) is 45.7kg.. very respectable imo. Considering I've heard of some of the brand name ones hitting 70+kg..
  5. The Following 6 Users Say Thank You to BigRAWesty For This Useful Post:
    Majestic (13th February 2015), mudnut (10th August 2013), SamIam (3rd April 2021), SharkyGQ (13th August 2015), SonOf (7th June 2013), Trolatron (3rd June 2013)
  6. #3
    Legendary Alitis007's Avatar
    15 Post(s)
    Nice work mate!! At least if its not plumb you can blame the father inlaw lol
  7. The Following User Says Thank You to Alitis007 For This Useful Post:
    BigRAWesty (15th April 2013)
  8. #4
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Nylon instead of bearings is good I reckon.
    tapatalk on galaxy note
    Thanks, Cameron
    No Patrol now - Just good memories!
  9. #5
    43 Post(s)
    Cheers guys. Yea the nylon is light as. Couple of grams per strip. Father in-law has been using it in his old 80 for 10+ years now without an issue.. and its always loaded with recovery gear..
    A bit more added to post 1
    Owner of
    Westy's Accessories
  10. The Following User Says Thank You to BigRAWesty For This Useful Post:
    sil3nt_dr3ams (12th August 2013)
  11. #6
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Mate, do you use a stopper of sorts when pulling the draw out?
  12. The Following User Says Thank You to NP99 For This Useful Post:
  13. #7
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    Well built man looks good and some really good ideas.
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
  14. The Following User Says Thank You to krbrooking For This Useful Post:
  15. #8
    43 Post(s)
    Quote Originally Posted by NP99 View Post
    Father in-law hasent, but knowing my wife I might. Something simple like a bit 40x16 to the front of the top frame once draws are in, before lid goes on..
    To stop it 100mm in I recon.
    But then it is nice to be able to take the pantry inside to load up for long trips..
    Owner of
    Westy's Accessories
  16. The Following User Says Thank You to BigRAWesty For This Useful Post:
    NP99 (17th April 2013)
  17. #9
    43 Post(s)
    Nice bit of marble for the pull out bench top...
    Owner of
    Westy's Accessories
    Feb 2013
    Broadford VIC
    Quote Originally Posted by Westy's Accessories View Post
    Owner of
    Westy's Accessories
    I just saved a few brain cells........good idea.
