14th April 2013, 09:34 PM
help ASAP !!!!!!!!!
hi every one ok i just changed my pump on my zd30 and now i cant get it to bleed all the out out the lines and pump is there a special way to do this any tips that ppl ,might know help needed ASAP
14th April 2013 09:34 PM
14th April 2013, 09:36 PM
Hardcore
Just use the hand pump on the fuel filter and crank it over for a bit maybe hope someone else can help
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of themselves without that law is both.
For a wounded man shall say to his assailant,
'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honour.
14th April 2013, 09:46 PM
Moderator
Did you change the fuel pump or the fuel filter?
The handed primer should sort it out for you. Can take a while though.
Check out my Toy -->
Rogue Dung Beetle
14th April 2013, 10:00 PM
Legendary
Filling the fuel filter might help too.
14th April 2013, 10:52 PM
you could disconnect fuel line at fuel filter and pressurise your fuel tank till it starts coming out near the fuel filter. then reconnect and start bleeding out your injectors one at a time until all of the air is out of the lines. Happened to me on my old 4wd when i changed the fuel pump was told to do this by my mechanic and started first time just wished i knew an hour earlier
14th April 2013, 11:41 PM
thanks guys i changed the fuel pump i have fuel at the filter and injector pump just not at the injectors !!i have been trying to bleed it up for about 2hrs but still nothing cant seam to get the air out of the injector lines
is there a correct way to carry out the bleeding or is it just hand pump it till the injetor pump is full and then crank the car over and loosen the injector pipes as needed ????????
im stumped on this one !!!!!!
15th April 2013, 09:00 AM
As far as I know you just crack the injector line at the injector end and pump away until you see a constant flow of fuel.
The Following User Says Thank You to mudski For This Useful Post:
dirtygu (15th April 2013)
15th April 2013, 07:17 PM
mudski
cheers mudski i have tryed this and still no fuel
15th April 2013, 09:15 PM
how long should it take once the pump is full to get fuel up to the injectors ????
15th April 2013, 09:25 PM
is the hand pump definately pumping? usually hand pumping till fuel out injector lines, should start piss of piss.
