Page 16 of 16 FirstFirst ... 6141516
Results 151 to 155 of 155
Thread: Recovery - The Fundamentals
  1. #151
    I’m confused Again Dazman
    As per above, where do I connect a soft bought shackle to the likes of any modern car with Aftermarket sharp as razors tow/recovery points?
    Yes this is a problem for sure. But let's consider in that recovery the soft shackle will be used at the anchor point, ie. The tree truck protector if the hook won't work or if the Double line pull is needed.
    We don't need to over Engineer anything, and the steel gear still has a place for sure. The Soft shackle should be used wherever possible though bearing in mind sharp edges.
    I recently also invested in a 50mm square hitch receiver specifically designed to take a soft shackle which I will run on the back of the62.
    MB (3rd July 2022)
    474 Post(s)
    I was under the impression that we could all throw away our old heavy gear and rely on soft shackles spruiked by so many here there and everywhere, not the case in my travels
    MudRunnerTD (3rd July 2022)
  6. #153
    Yeah we really are in an extended transition period mate, fast forward another 10 years and there will be very few recovery points with sharp edges. It's coming, we aren't there yet though. As I replace or update gear I am certainly making choices around my want to use Soft shackles.
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (3rd July 2022)
  8. #154
    474 Post(s)
    Thank God, someone’s going to outlaw any vehicle bought pre 2022
  9. The Following User Says Thank You to MB For This Useful Post:
  10. #155
    Bhahahaha. Mate if VicPol had there way every GQ would be crushed yesterday. Lol.
  11. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Hodge (4th July 2022), MB (4th July 2022)
