5th February 2021, 08:16 PM
#141
Administrator
MudRunnerTD
what is actually pretty scary in that last pic is that Most of that Damage is from the Strap..... Not the shackle! Brutal! Imagine that hitting you!
Do you mean the strap did the wider damage on the door?
Brutal impact and bloody lucky!
5th February 2021 08:16 PM
5th February 2021, 10:33 PM
#142
Moderator
AB
Yes mate. You can see where the shackle hit as an impact puncture but the massive spread of damage to both doors is all Strap. That is a Tough bit of door too!!!
Check out my Toy -->
Rogue Dung Beetle
20th February 2021, 02:14 PM
#143
This finally arrive from the US whilst on shift. very nicely finished, now just have to practice using it to get the benefit.xlock.JPG
The Following 3 Users Say Thank You to PeeBee For This Useful Post:
MB (21st February 2021), mudnut (20th February 2021), MudRunnerTD (20th February 2021)
21st February 2021, 06:32 AM
#144
This chap seems to have some helpful videos found I’m learning on too folks:
https://youtu.be/s1h9whPOPn0
The Following 2 Users Say Thank You to MB For This Useful Post:
PeeBee (21st February 2021), Rossco (21st February 2021)
21st February 2021, 01:06 PM
#145
Good clear explanations and easily understood. Its really simple trig stuff when it comes down to it, 'triangulated ' forces or vectors, easily missed in the field under duress and when the operation appears to be nothing like the theory. Good find @MB
22nd February 2021, 11:52 AM
#146
The Following User Says Thank You to MB For This Useful Post:
Rossco (22nd February 2021)
15th August 2021, 10:02 AM
#147
Moderator
Hodge
This is a Great Video about the Maths of using a Bridle to centralise the load across the chassis.
Fundamentally we need to consider the side load when winching from an angle. This video explains it quite well.
Using a single length bridle across the points rather that 2 3m straps to the hook. 1 6m strap with the hook around the middle that can slide.
The further away from the vehicle the centre of the bridle is the Les the angle and the less the side load is. A 6m bridle, so 3m each return, seems the best option.
Do yourself a favour and Watch the Video.
Thanks for the content Hodge!
Rogue Dung Beetle
3rd July 2022, 08:49 PM
#148
MudRunnerTD (3rd July 2022)
3rd July 2022, 10:40 PM
#149
Moderator
@MB nice one mate. Yeah I have quite a few soft shackles now. Still like the ones I made as the strongest I have as they are the only ones made from 12mm rope. Over the gear stick for the storage win for sure.
I have a snatch ring which I have used a few times now and recently bought another through a big sale discount, when it turned up it is made for 12mm rope and is about 150mm across so a really good diameter too. Stoked.
I also grabbed an 18mm Kentic Rope which is snazzy. Not a big fan of snatching and in the GQ will always Winch cause 24Vforlife. But it could see some use in Cape Jaffa.
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
Hodge (3rd July 2022), MB (3rd July 2022)
3rd July 2022, 10:47 PM
#150
