Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 155
Thread: Recovery - The Fundamentals
    I am a Driver Trainer with my club and last year had to put together an Advanced Course for Winching and Recovery.
    Below is some good information that i put into a Course Book for each of the Participants.
    I did not write allot of it but compiled it here from a number of places and put it together here. I acknowledge the work of 4WD Action Mag for quite a bit of the detail.
    Advanced Recovery - Tips and Techniques
    Basic Recovery Gear
    Rated Recovery Points, Snatch Strap, 4.5t “D” Shackle,
    Winch, Tree Trunk Protector, Winch Extension Strap,
    Snatch Block, Winch Dampener Blanket, Hand Winch,
    Gloves,
    Not everyone will carry all of this gear, some of it should be carried as personal safety equipment and the rest could be carried amongst the group if you are travelling in a convoy.
    Minimum requirement with any Four Wheel Drive vehicle should be a snatch strap and pair of gloves.
    Recovery of a Vehicle
    Recoveries are a difficult task and should not be attempted lightly. There are risks involved to vehicles and people and all the risks should be considered before any recovery is attempted.
    Check list for safety
    1. Secure the Vehicle – is the vehicle in danger of sudden movement? Can I Secure it via a tether line for safety?
    2. Is there a risk to people? What can I do to reduce the risk?
    3. What kind of terrain is it?
    a. Is it flat?
    b. Is it a bog hole?
    c. How deep is the mud that I am in?
    d. What is the angle of slope of the hill?
    e. What affect will the slope have on the weight of the vehicle?
    f. What recovery gear do I have?
    g. What is the recovery gear rated too?
    h. How many people really need to be involved in this recovery – Can I clear the hill, move people away?
    i. Who is in-charge? – There should only be one person in-charge of the recovery.
    j. Ask for advice from others, don’t be shy.
    4. Can I lighten the load on the recovery equipment?
    5. Be willing to think outside the square.
    Buying the Right Winch
    Remember this. It might save your life or your vehicle.
    There are very few, if any, industry standards when it comes to the claims that can be made about winches and load rated gear and vehicle based winching.
    Winch Manufacturers can make all sorts of claims about load rating and line speeds and the consumer will have very little if any option but to believe them. This is probably one reason why so many different brands have sprung up over the last few years – Because They Can!
    Why Buy a Warn Winch for $1700 when you can buy an Ebay Chinese copy for $400? Please read the last paragraph and think about it hard when you are swinging off that winch cable with your family in the car on 30 degrees next time! Consider a second hand Warn for $800 or don’t go down that track.
    If the local hardware store or Ebay seller had to run their winches through the NATA laboratory test or similar to prove all of the claims on the box, perhaps it wouldn’t bother selling it in the first place. This isn’t to say that all Asian winches are a dud, far from it! But can you tell the difference?
    There are stories of some of these Asian winches being used heavily in the field and not only passing the test, but thriving. The problem is? Do you know which one? And was it built the same as the one beside it sharing the label?
    Given that winching is one of the most dangerous and potentially Lethal 4WD operations you can undertake, you really want to know the risks that you face and whether your equipment is up to the task?
    Before you hit the track, the smartest thing to do is to run your loaded vehicle over a weighbridge. This gives you a “Loaded weight” of your fourby and will probably be as much as 1.5 times it bare weight. Of course if you are on a big expedition your vehicle could be as much as twice its bare weight. So obviously this would be really good to work out. You are then making your decisions in relation to recovery with a true indication of weight of your vehicle.
    Basic Winching and the Affect of Slope.
    Winching on flat ground in a straight line is pretty well as safe as houses as long as you adopt safe work practise. The load is well within the ratings of the equipment on every 4WD. But who does that?
    Standing clear, Using a Winch Blanket and connecting to a Rated Recovery Point on the vehicle is all that should be needed to extract the vehicle.
    How much are you really pulling up that hill when you are swing off a winch cable on a 30Degree slope? And what about when you are bogged to the axles or sitting on your belly in the mud? Sticky Otways Mud?
    What if you have to winch around a corner? How do you do that?
    There are basically four different types of resistance that you will encounter while off roading that affect the load on the winch. These include:
    1. Surface Resistance.
    2. Slope Resistance.
    3. Bog Resistance.
    4. Damage Resistance.
    The figures below come from extensive reading and research and a dash of commonsense. As explained earlier, there is no comprehensive list of regulations for recovery that contain this information.
    To move or pull a 4WD on a firm flat bitumen surface requires a force of just 10% of the loaded weight of the vehicle. To do the same on gravel or grass increases this to about 33% of the loaded weight of the vehicle.
    Throw an incline in and that maths increases significantly.The percentages need to be added to the loaded weight and can change things dramatically and quickly increase the weight being recovered to far beyond the capacity of the equipment.
    For an Incline, or Up Hill, the following extra weight should be added to the loaded weight of you vehicle as a guide:
    15degree Slope == add +25% of the loaded weight
    • 30degree Slope == add +50% of the loaded weight
    • 45degree Slope == add +75% of the loaded weight
    On flat ground no change is required
    For a Decline, or Downhill, the following weight can be deducted from the loaded weight of you vehicle as a guide:
    • 15degree Slope == subtract -25% of the loaded weight
    • 30degree Slope == subtract -50% of the loaded weight
    • 45degree Slope == subtract -75% of the loaded weight
    Basic Winching and the Affect of MUD.
    But what if your bogged? If your fourby is bogged in the Mud then the depth of the bog will have a massive affect on the loaded weight of the vehicle.
    Below is a guide only for calculating the dead weight of the vehicle when in mud.
    Bogged to the Base of the Wheel Rim, you will require a pull of 100% of the load
    Bogged to the wheel Hub, the weight doubles! You will require a pull of 200% of the load
    Bogged to the Belly or the Chassis and it is x3! You will require a pull of 300% of the load
    And lets face it, the later is when winches are really being asked for.
    Apply these weight variants to ALL of your RECOVERY gear!
    Consider these variations when you are looking at your vehicle and considering how you will extract it form its position. Consider being stuck in the mud to the chassis on a 25degree slope!!!
    Pounds Vs Kilograms – the Real Story.
    Why do we have winches on our vehicles that quote the mass weight strength of the line pull in Imperial Pounds when we are living in a Metric System of Measure.
    It because the bench mark brands of winches originate in the USA where it is all about pounds.
    And lets face it 8000lbs sounds much tougher than 3600kgs! Imagine the Warn High Mount called the 3.6.
    Get to know your gear and get to know it in the Metric world. Do the conversions and document them in your vehicle if you cant remember them. Send it to yourself as a text message on your phone so you never forget. This will save your life.
    For the record - 1lb equals 0.454kgs, or 1kg equals 2.2lbs.
    8000lbs = 3632kgs
    9000lbs = 4086kgs
    10,000lbs = 4540kgs
    12,000lbs = 5448kgs
    Scenario
    So, your average GU Patrol for example has a loaded weight of 3.3t (2.2t tare by 1.5t). Your stuck to the chassis, so you will need to pull 9.9t out of the muck (3.3t x 300%)
    Throw on a camper trailer (1t) and your Nissan’s winch and recovery gear needs to deal with 12.9t!
    Now look at the list above and see the problem you are in!!
    Enter the Snatch Block!
    An introduction to the Power of the Multi-Line-Pull.
    We’ve just worked out that, by itself, your winch is in big trouble. The electric winch has many limitations and is not the be all and end all. By itself it is very handy and will give many an inexperience four-wheel driver a false sense of security and confidence and can get you into more trouble than it can get you out of if in the wrong hands.
    This is why we like to use the humble Snatch Block. You cant have too many of these. If every one has one then you may have many on a hill. This is all good.
    The snatch block is a rated piece of equipment that allows the cable to run over a pulley and change direction too another tree or back to the winching vehicle.
    The awesome power of the Snatch Block is that as soon as you introduce a pulley within the line you HALVE the weight on the line!! Add 2 Snatch Blocks and you reduce the weight to 25% of the line weight at the hook!
    Add Three? Well, then you will reduce the load on the winch to 1/8th of the load on the hook. This is called a Triple Line Pull. It is slow but very effective.
    Remember, every time you add a Snatch Block you halve the weight, but also halve the speed of the winch but double the power so who cares.
    **Very Important.. The mathematics that we have set out here is only true if the pulley is set up to allow the pulley wheel to turn with the cable.
    The Weakest Link
    **Very Important
    Remember that the main reason that we introduce Snatch Blocks is to halve the weight on the winch effectively allowing us to pull far in excess of the pulling power of the winch.
    Often when Snatch Blocks are introduced the winch line is used up in the double or Triple line pull and we have to use a Winch Extension Strap. What is the rating of this strap?? The more Line pulls the more likely that you can introduce a weight beyond the breaking strain of the strap. This is very easy to do and it is disastrous.
    Massive loads are placed on your recovery system when introducing Snatch Blocks; so think about all of it every time you use it, when ever you pull it out and after you pack it away!
    The Final Check List
    1. Is your recovery Hook rated and to what level?
    2. What is the breaking strain on the Winch Extension Strap?
    3. What about the Tree Truck Protector?
    4. The Shackle?
    5. What does my Winch cable look like?
    6. What does it look like now?
    7. Did I pack it away and re-spool it properly?
    8. Have I lubricated it?
    9. Is that winch cable that I will hang off one day just a rusty Birds nest on the front of the vehicle or re-spooled and lubricated ready for use?
    10. Have I put any of my gear under extreme load before? And should it be replace?
    Rule Number 1
    Work Safely, Protect Life.
    Determine the load,
    Assess the Environment.
    THINK!!
    Enjoy the drive, Tread lightly
    Special thanks to Australian 4WD Action for being a great Resource
    Cheers MudRunnerTD
    AKA Darren
  2. The Following 45 Users Say Thank You to MudRunnerTD For This Useful Post:
    2TROLLFAM (22nd March 2012), AB (30th August 2011), AJTich (29th October 2013), Andy76 (30th September 2016), basil (11th May 2013), Ben gu8dx (23rd March 2014), Bigrig (16th December 2010), Blacklotusdog (11th July 2012), Bluecrab (2nd June 2013), Chubba (28th June 2015), CoGRedeMptioN (15th April 2012), Cuppa (12th January 2011), damianovdd (11th February 2011), Dman2603 (24th March 2015), Dr Gary (24th January 2012), DX grunt (16th December 2010), Family4x4 (13th July 2014), Finly Owner (17th December 2010), Gecko17 (15th August 2013), HallyGUTE (23rd March 2012), jman69 (14th September 2012), karllovesmercedes (4th September 2013), LaughingBeagles (13th October 2015), Lexx (3rd April 2015), LukeV (21st January 2013), Maxhead (16th December 2010), MB (21st February 2021), MC97GQ (3rd March 2012), molongmick (1st April 2011), Mrowka (15th January 2011), mudnut (11th November 2013), my third 256 (16th December 2012), NissanGQ4.2 (16th December 2010), nowoolies (29th August 2011), num_301 (21st May 2012), Old Wal (2nd August 2012), qwertytank (16th December 2015), Sir Roofy (10th January 2011), snicko (22nd July 2011), twisty (22nd July 2011), Warwick89 (12th December 2013), Waza (15th December 2013), Winnie (6th January 2016), Woof (15th December 2010), YNOT (16th December 2010)
    Slope v Weight Calculator
  5. The Following 15 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (30th August 2011), Ben gu8dx (23rd March 2014), Bigrig (16th December 2010), Black Rock (12th April 2012), Dman2603 (24th March 2015), Finly Owner (17th December 2010), Gecko17 (15th August 2013), HallyGUTE (23rd March 2012), Mrowka (15th January 2011), my third 256 (17th December 2010), Old Wal (2nd August 2012), rusty_nail (27th January 2012), Sir Roofy (10th January 2011), Warwick89 (12th December 2013), Woof (15th December 2010)
  6. #3
    I did not want to have this bit lost in the Soup of the above post.
    The young fella that died in QLD on the weekend would still be alive if they did the maths and understood the affect of
    HOW DEEP THE MUD IS DETERMINES HOW MUCH YOU WEIGH.
    If you have a Snatch strap rated at 4,500kgs then by the calculations below you should not even think about pulling it out if your up to the Hub in Mud.
    My GQ weighs in at around 2,800kgs. If i was in a Bog hole sitting on my guts i would need a Snatch strap rated at at least 300% of my weight = 2,800kgs X3 = 8,400kgs!! and that is without the slope of the entry or exit out of that bloody Bog hole. Add "affect of slope here">>>
    Rule Number 1
    Determine the load,
    THINK!!
  7. The Following 6 Users Say Thank You to MudRunnerTD For This Useful Post:
    Almost Dun (6th January 2011), Dman2603 (24th March 2015), Finly Owner (17th December 2010), Gecko17 (15th August 2013), Mrowka (15th January 2011), rusty_nail (27th January 2012)
  8. #4
    So in this pic i am up to nearlly my chassis and way over the hubs. I reckon i was 250% over weight.
    .This would equal a winch pull of 7000kgs! NOT KIDDING.
    HOW ABOUT THIS ONE - 300% = Line pull or snatch of 8,400kgs
    How about this one? Double line pull on an Up spec'd Hi Mount.
    SLOPE + DEPTH OF MUD + WEIGHT OF CAR + QUANTITY OF ORGANIC MASS BEING PUSHED OUT IN FRONT
    25 Degrees = Load (2,800kgs) + 45% = 4,060kgs X 300% for mud = 12,180kgs
    PLUS the wieght of the Organic mass out the front (About 3m3) and we were up around the 15,000kgs!!
    Put in a Snatch block and that is halved to 7,500kgs, and what is the Hi Mount rated at? 3,632kgs!
    Should have done a triple line pull...Even a Triple Line pull would be 3,250kgs!, near the max capacity of a HiMount.
    And it felt every bit of it!!
    That is not my car, i took the photo, i was next through that hole though and i did a triple line pull and it was still a very big pull out.
    This was the first of about 10 holes just like it that day. You have to be very switched on and get it right or things go wrong.
  9. The Following 18 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (16th December 2010), AJTich (29th October 2013), Almost Dun (6th January 2011), clivelm (4th April 2014), damianovdd (11th February 2011), Dman2603 (24th March 2015), DX grunt (5th January 2011), Finly Owner (17th December 2010), Gecko17 (15th August 2013), Mrowka (15th January 2011), Old Wal (2nd August 2012), Plasnart (16th December 2010), rusty_nail (27th January 2012), snicko (22nd July 2011), twisty (22nd July 2011), Warwick89 (12th December 2013), Woof (16th December 2010), x4by4 (30th January 2014)
  10. #5
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Awesome, Awesome work mate - well done on putting this up!!!! Full marks to you!!!
  11. #6
    581 Post(s)
    Great work mate, thanks for taking the time to post this up.
    This information is A+++ and I'm sure every single person who read's this has learnt something regardless of your skills.
    Well done mate!
  12. #7
    Jul 2010
    Waterford West Qld
    Excellently spelt out. I wasn't aware of all of that.
    Is this sticky?
  13. #8
    Cheers Guys, please feel free to share it around, a Safe Recovery is an Educated Recovery. Nobody knows Everything.
    Cheers Darren
  14. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    Clunk (28th December 2010), Gecko17 (15th August 2013), nowoolies (29th August 2011), Woof (17th December 2010)
  15. #9
    Nov 2010
    Without wishing to distract from the very useful MudrunnerTD posts, there are two things I would add -
    1. Maintain all recovery equipment in top condition or make out your will.
    2. Keep your cool when you get stuck, bogged, etc.
    In terms of difficulty, mud is probably the worst recovery situation. Everything slips and slides and gravity is your arch enemy. Sod's Law of Mud Recovery is - "Your capacity to imagine a worse situation is always exceeded by reality."
  16. The Following 5 Users Say Thank You to tkn For This Useful Post:
    AB (5th January 2011), DX grunt (5th January 2011), Finly Owner (5th January 2011), snicko (22nd July 2011), twisty (22nd July 2011)
  17. #10
    581 Post(s)
    Quote Originally Posted by tkn View Post
    Good points Tkn!
