13th March 2015, 01:49 PM
#91
I am he, fear me
Throbbinhood
Sorry, I didn't quite phrase my question that well. It's less of a 'not being room to turn', and more, say im going up a hill, and turning is impractical because of angles. I could go up, turn around, and come back down, but that would mean having to reverse back up the hill, which would present it's own set of dangers, and may not be practical. But if it effectively works as a redirect then it should be sweet
Yeah, it's the old "in theory" thing.
In practice trying to rig from the centre of your vehicle out to one side or the other then back down to the stranded vehicle is almost always impractical due to not having enough snatch blocks, winch extensions etc .
Put it this way, with a standard length winch cable, one or two snatch blocks and one vehicle behind the other it just is not going to happen.
You are going to have to rig forward at a small enough angle to not side load your winch OR use a snatch block redirect to get to the side THEN, another snatch block to redirect back and I would suggest at least 1 probably 2 more to redirect onto the front of the stranded vehicle and/or clear the ground
That is a lot of cable and blocks and you still have only 1:1 line pull
One option would be rigging his vehicle to the rear of yours and winching/driving in concert using the gear on your vehicle to give you a 4:1 advantage on your winch.
The Following 3 Users Say Thank You to the evil twin For This Useful Post:
krbrooking (14th March 2015), threedogs (19th June 2015), Winnie (13th March 2015)
13th March 2015 01:49 PM
13th March 2015, 01:58 PM
#92
the evil twin
That sounds like the go. Thanks for the help mate.
22nd March 2015, 07:06 PM
#93
Another quick one.
Found a bloke on the weekend who went too quick around the corner and was almost over the side, car was balancing on its chassis and would have been a long way down. We had two cars with winches to recover, and chose to run pulleys off a tree to redirect and basically pull him sideways (our thinking here was that it pulls our cars towards safety as well as his, rather than a direct pull which may have just pulled us towards the edge).
Question is, if only one of us had a winch and was struggling to pull sideways with only the redirect, would have a pulley from the stuck vehicle back to the tree with the redirect give us an advantage?
22nd March 2015, 07:53 PM
#94
I am he, fear me
16th April 2015, 10:41 AM
#95
thanks for the good info. we expect a lot from our winch cables .
18th June 2015, 04:55 PM
#96
I may have missed this elsewhere
When I use a pulley to setup a mechanical advantage and hence reduce load on the winch, do I also reduce the load on the rope/shackles/pulleys?
For instance, say I'm doing a 3T winch pull, with no pulley it's 3T on the winch, rope, straps. With a pulley involved, it's 1.5T on the winch, is it also 1.5T on everything else?
18th June 2015, 07:37 PM
#97
I am he, fear me
Throbbinhood
1.5T on the winch drum
1.5T on the winching vehicle anchor point and any rigging
1.5T on the cable from the winch to the snatch block
1.5T on the cable from the snatch block back to the vehicle anchor point (it is the same cable so must have the same load)
3.0T on the snatch block (2 cable loads at 1.5T each)
3.0T on the anchor point of the snatch block and rigging to whatever you anchored the snatchie too.
The Following 4 Users Say Thank You to the evil twin For This Useful Post:
lucus30 (18th June 2015), macca (16th March 2017), MudRunnerTD (18th June 2015), threedogs (19th June 2015)
19th June 2015, 10:52 AM
#98
the evil twin
Thanks mate
Is there ever a case where you multiple or increase the load on equipment by hooking up redirects/double/triple line pulls? Or for the most part it halves, and stays the same as original on things like pulleys and anchor point the pulley is connected to?
19th June 2015, 12:58 PM
#99
I am he, fear me
Throbbinhood
Thanks mate
Halving loads etc only works in a perfect world.
Real world use means snatch blocks, pulleys etc introduce their own loads IE depending on dia, cable type etc it may be that you only get a, say, 45% reduction instead of the full 50.
That is no biggee unless you are up on the ragged edge.
The other thing to be aware of is Sling Load Angle on bridles, very common, or if loading a redirect which is quite unusal but may be handy if recovering or winching around a curved path
19th June 2015, 02:47 PM
#100
the evil twin
Thanks mate - I just want to make sure I don't ever increase the load on components. Would hate a triple line pull to result in a 3t pull being 9t on the snatch block, but from the sounds of it, the snatch block only ever gets the original load sort of thing.
