Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: 33's on Standard GU
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    33's on Standard GU
    Hello fellow forumeers,
    Been pricing up tyres for the patrol as I need to replace them before next rego inspection, Got some prices today on some Kumho KL78 a/ts theres $10 difference between the 265/75/16 and the 285/75/16
    If I can I'd rather go the bigger size, I plan to go to a 2" lift down the track but would rather get the bigger tyres now if I can fit them, I'd expect scrubbing on full lock which doesn't bother me too much as long as height will be ok.
    Would really appreciate some opinions on this.
    Kind regards,
    Eric.
    North brissy
    285's will go easy mate. They aren't as wide as a 33x12.5 and if your getting a 2" lift they will be well suited.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    trekster (13th April 2013)
  5. #3
    Hardcore
    Coffs Harbour
    G'day Eric,
    As recommended by Matt. I have 285/75/16 on my Patrol and you are welcome to have a look at mine. PM with your contact phone number so we can meet.
    Regards,
    RLI
    The halls been rented the bands been paid, time to see you dance!
  6. The Following User Says Thank You to PMC For This Useful Post:
  7. #4
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Quote Originally Posted by RLI View Post
    G'day Eric,
    Regards,
    RLI
    Are you running standard rims ?
    Maybe pop some pics up ?, we love pics
    <a href=http://i83.photobucket.com/albums/j320/02ard/PatrolcomAvatar-1-1.jpg target=_blank>http://i83.photobucket.com/albums/j3...Avatar-1-1.jpg</a>
  8. #5
    I ran 285s on STD rims before my 2" lift no issues at all.
    Now I run 305s on a 2nd set
  9. The Following User Says Thank You to threedogs For This Useful Post:
  10. #6
    Nov 2012
    Coffs Harbour, NSW
    Thanks for the replies, just wanted to make sure they would be ok in the interim until I get the lift kit, funds are tight at the moment otherwise I would do the lift as well.
    Cheers,
    Eric.
    1998 GU RD28T: RIP
    1996 GQ RD28T: RIP 11 days later
    Hello 2012 GU CRDZD30
    Nissan winchbar + Warn, Dual Battery/Redarc, UHF and Titan rear drawers
  11. #7
    Expert Diesel-Mate's Avatar
    Sep 2012
    Gold Coast
    285/75r16 are about 31.8inches in diameter and 11.6 wide.
    315/70r16 are 33.2inches in diameter and 12.2 wide.
    I would opt for the 315, they are a much better tyre.
    Sent from my HTC Sensation XE with Beats Audio Z715a using Tapatalk 2
    TD42 turbo GQ - ironman snorkel - 4 inch flexy coils - 6" shocks - 3" straight exhaust - pyro and boost gauges in A pillar- uhf - winch - sunraisers - Bluetooth - spotties - front lokka
  12. #8
    Sep 2012
    Gold Coast
    Also those tyres will fit without a lift but you will most likely need to remove the front mud flaps. What type of lift are you wanting to run?
  13. #9
    Nov 2012
    Coffs Harbour, NSW
    Quote Originally Posted by Diesel-Mate View Post
    Cheers for that, just a 2" lift in 6 months or so.
    Regards,
    Eric.
    1998 GU RD28T: RIP
  14. #10
    I differ with your conversion
    My memory says 285s are same as 33s but only 11.5 in
    305s a tad bigger than 33s but wider at 12.5
    315 were 34.5 and as you stated will rip front mudflaps off without a lift.
    No biggy but maybe someone else could confirm
    Pic is 305s /2" lift
    Mags are 285s @ 2" lift
    305 is width in mm 70 is % of width {Aspect ratio} for sidewall and 16 is rim size
    so 285 is width in mm 75 is % of width{aspect ratio} for sidewall and again 16 is rim size
