Results 1 to 9 of 9
Thread: Left blinker blinking fast
    Advanced
    Jan 2013
    Darwin
    4 Post(s)
    Hi guys,
    Yesterday my left hand side blinker in my 2007 GU started blinking a lot faster than usual. The right side works normally, and both flash normally with the hazards on.
    Any ideas what might be causing this?
    Thanks,
    Jaycee
    Patrol Freak
    Sep 2011
    adelaide
    18 Post(s)
    check for a blown globe and also check for a loose wire in the trailer plug if you have one
    Advanced
    Jan 2013
    Darwin
    4 Post(s)
    Quote Originally Posted by pearcey View Post
    Thanks Pearcey, will do. I had a rear bar installed last week, so i'm thinking they may have accidentally pulled a wire or something. Could just be a coincidence though.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Does the rear bar have LED lights fitted?
    If so and there are no blown bulbs for the LHS indicators you will either need to fit a load resistor to the indicators or replace the flash relay with an LED compatible one.
  6. The Following User Says Thank You to Yendor For This Useful Post:
    rusty_nail (11th September 2013)
  7. #5
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Or maybe an earthing problem?
  8. #6
    Mar 2013
    Mackay, QLD
    It could also be the relay on it's way out. Relays are known to flash faster than normal when they are about to give up and die.
  9. #7
    Mar 2013
    You did check if none of the left hand blinkers failed? Quick blinking would normally indicate a bulb lost in the chain.
  10. #8
    Beginner scott.a.green's Avatar
    Aug 2013
    Sounds like a globe or flasher relay is gone mate.
  11. #9
    brisbane
    Quote Originally Posted by Yendor View Post
    Wouldn't that make left and right flash at the same rate as the bar would have the same indicators left and right
