Results 1 to 10 of 10
Thread: Intercooler rubber mounts needed
    Advanced Stokezi's Avatar
    Newcastle
    Hi all l am after the rubber mounts for a zd30 intercooler if anyone has some to sell or if anyone knows who sells them that would be great as l have not had much luck finding any
    brisbane
    I'd go to a wreckers
  4. The Following User Says Thank You to megatexture For This Useful Post:
    Stokezi (9th April 2013)
    Newcastle
    No luck with local and surrounding wreckers yet going to extend my search via phone this weekend QUOTE=megatexture;358840]I'd go to a wreckers[/QUOTE]a
    460 Post(s)
    I got some rubbers from Clarke Rubber. Like the rubber wiring grommets. Worked and fitted fine.
  8. #5
    brisbane
    Try Clark rubber and see if they have some rubber grommits that might fit ?...
    Beat me to it lol
  9. The Following User Says Thank You to megatexture For This Useful Post:
  10. #6
    Newcastle
    It's the rubber mounts that the bolts go through to hold the intercooler in place so it doesn't vibrate ,missing just 1 so do u think clark rubber would have that
  11. #7
    460 Post(s)
    Quote Originally Posted by Stokezi View Post
    You will find you will have to replace all of them so they are the same. The CR ones are different to the OEM rubbers but still work fine.
  12. The Following User Says Thank You to mudski For This Useful Post:
    Stokezi (11th April 2013)
  13. #8
    brisbane
    These the ones you used mudski http://www.clarkrubber.com.au/wiring-grommet.html
  14. The Following User Says Thank You to megatexture For This Useful Post:
  15. #9
    May be even able to use some soft poly block from CBC bearings and just drill hole in centre.
  16. The Following User Says Thank You to threedogs For This Useful Post:
  17. #10
    460 Post(s)
    Quote Originally Posted by megatexture View Post
    Yeah something like that. I actually took my IC into CR to get the sizing right. For under $10 I had new mounts.
  18. The Following User Says Thank You to mudski For This Useful Post:
