Results 1 to 9 of 9
Thread: Lsd
    Mar 2013
    penrith
    Lsd
    hi guys got a question
    the gq I bought is a base model and
    doesn't have LSD but when I purchased the car
    I was given an LSD and bearing kit for the diff
    what's the rough cost of getting the LSD
    shimmed and installed with the new kit
    also I'm in penrith western Sydney
    also is there a difference with bearing etc with
    drum brakes which I have and discs?
    thanks guys
    Mate it will have an LSD. It might not work but it will definitely be an LSD.
    Oct 2011
    Essendon
    I think some of the early base models did get released without an LSD.
    It's a relatively straight forward job. I would think it'll be 500 to a grand, depending on how much the workshop needs the business....
    Tip tip tip......tap tap tap....
  5. The Following User Says Thank You to Drewboyaus For This Useful Post:
    fjp510 (8th April 2013)
    Hardcore healy's Avatar
    south east melbourne victoria
    Yeah it will be around $500
    IF ITS NOT BROKEN IT MUST BE A PATROL
    Mar 2013
    penrith
    is there any code on the compliance plate
    or that to tell if it came with an LSD?
    Expert 90mav's Avatar
    Dec 2012
    Gold Coast
    If in doubt, just swap the whole rearend for a LSD disc brake one. Got to better all round and you can pick up a whole rear end cheaper than $500
    Patrol Guru
    Apr 2011
    Melton
    Have you checked if you have a LSD fitted see
    http://www.youtube.com/watch?v=TI8ewn6HOjg
  10. #8
    Feb 2014
    Shim and install it urself it's not a hard job at all few posts on the net to guide you though it only cost you time shim and oil
  11. #9
    Aug 2010
    adelaide
    sounds like a meetup at your place for work on the diff
    OH LEATHER IS NICE
