8th April 2013, 08:00 PM
Lsd
hi guys got a question
the gq I bought is a base model and
doesn't have LSD but when I purchased the car
I was given an LSD and bearing kit for the diff
what's the rough cost of getting the LSD
shimmed and installed with the new kit
also I'm in penrith western Sydney
also is there a difference with bearing etc with
drum brakes which I have and discs?
thanks guys
8th April 2013 08:00 PM
8th April 2013, 08:10 PM
The 747
Mate it will have an LSD. It might not work but it will definitely be an LSD.
8th April 2013, 08:46 PM
CERTIFIABLY INSANE
I think some of the early base models did get released without an LSD.
It's a relatively straight forward job. I would think it'll be 500 to a grand, depending on how much the workshop needs the business....
Tip tip tip......tap tap tap....
1997 GQ Patrol RX, TB42E. Mods: OME 2" lift, 33" BFG KM2'S, ARB winch bar & reconditioned X9 Superwinch, IPF 900 spotties HID conversion, ARB side steps and scrub bars, Kaymar rear step & spare wheel carrier & jerry holder, Rear 55W LED worklight, Safari Snorkel, 147L LRA tank, Extended diff breathers, dual batteries, GME UHF, Home built drawer and fridge slide, ARB 60L fridge.
The Following User Says Thank You to Drewboyaus For This Useful Post:
8th April 2013, 08:48 PM
Hardcore
Yeah it will be around $500
IF ITS NOT BROKEN IT MUST BE A PATROL
8th April 2013, 08:58 PM
is there any code on the compliance plate
or that to tell if it came with an LSD?
12th April 2013, 05:10 PM
If in doubt, just swap the whole rearend for a LSD disc brake one. Got to better all round and you can pick up a whole rear end cheaper than $500
16th April 2013, 11:31 PM
Have you checked if you have a LSD fitted see
http://www.youtube.com/watch?v=TI8ewn6HOjg
1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
And its Toooooooo High for the Ball & chain
28th February 2014, 11:41 PM
Shim and install it urself it's not a hard job at all few posts on the net to guide you though it only cost you time shim and oil
1st March 2014, 08:52 AM
Legendary
sounds like a meetup at your place for work on the diff
2007 GU 6 /ST-L / MYO8 / DIESEL/AUTO /MOONSTONE /pro vent 200
OH LEATHER IS NICE
