Results 1 to 6 of 6
Thread: '98 GU RD28T alternator, can I drive without it?
    Jul 2012
    Perth
    Question '98 GU RD28T alternator, can I drive without it?
    My alternator has thrown a bearing and seized, problem is I'm in the bush and waiting for parts to come to me will be quite some time.
    All my manuals ect are at home so now I have this question, if I remove the alternator drive belts can I run the car on battery alone for a few hundred km's?
    Is anything else driven from the alternator drive belts?
    Cheers,
    Grahame?
    Expert Rip'n'Shred's Avatar
    Hunter Valley, NSW
    I don't know if anything else runs on the alternator belt. Best to have a look if your stuck. Apart from that it should be ok till your battery runs flat as far as I know.
    I wouldn't be surprised if the water pump runs on the same belt though. You wouldn't want to run without the water pump turning.
    GU IV 2006 4.2 TDi wagon
    Advanced philfree's Avatar
    Oct 2011
    Gympie, QLD
    yer the big one is the water pump i don't have a 2.8 but my 4.2 has 2 belts doing 2 different things so i could take a belt off and keep driving till the battery goes flat be very carefull about driving with no water pump won't go to long at all , having said that if your realy stuck and they both run to the alternator you might be able to rig something like a stocking from the crank to the water pump to get some flow going
    00, Dx 4.2 turbo, dual batt, 3in exh, Boost contrl, boost and egt guages, GTX2867r, cc intercooler, 3.5in airbox mod, roof console,4 x hid spots and hid projectors, snorkle ,winch,reverse lights and tinted windows, safari tuff clutch, now tuned to 155rwhp also 2000 ford fairmont ghia, 1987 mitsubishi 4wd ute converted to buggy
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Also dont want a flat battery while driving. It feeds power to the on board computer!!!!
  6. #5
    Jul 2012
    Perth
    Thanks for your replies, there is two belts on here, with three pulleys, alternator,fan and another one below the fan.
    If I can just confirm which is the water pump now ill be right. Have dual batteries setup and a generator to charge when needed.
  7. #6
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    I drove over 800 Kim's last year with no alternator and the 2 batteries linked together. Apparently ignition runs at about 4 amps per hour. If you have solar panels put the on the roof and connect to the batteries that will help a bit.. You should make it with no radio air con etc on and batteries fully charged.
    Scotty
