7th April 2013, 04:27 PM
oil leak at rear of motor
any ideas just started to get oil leak on zd30 at the bottom of the block where the bellhousing meets the motor. only started after some hard driving on the powerlines track. i'm hoping its not the rear main seal if so, how hard is it to replace and anyone know of anyone in perth northern suburbs? replaced oil and put a stop leak in to see if that will rejuvenate the seals. help please...... as with most nissan owners she's my pride and joy !
7th April 2013 04:27 PM
7th April 2013, 04:47 PM
Hope its not, but remove engine cover as it might be trickling down back of motor from the top
With cover off whip down car wash.
Manual or Auto???
7th April 2013, 04:48 PM
7th April 2013, 04:58 PM
Legendary
You really need to Pressure Wash it all to find out where it is coming from.
Make it crystal clean, go for a drive, and that will help you determine if it is coming from the rear and dribbling down from somewhere else..
Mic
7th April 2013, 05:52 PM
Legendary
threedogs
Manual or Auto???
With some luck it might be the rocker cover gasket!
8th April 2013, 08:16 PM
yeah unfortunately i think it is the rear main seal i think i was just hoping it wasn't . googled how to fix and it seems to be very common after playing in mud and water is this true? used to play in the mud with my old car but that used to leek like a pig anyway.
8th April 2013, 08:19 PM
oohh nearly forgot anyone know of any places in perth that do a good job but don't charge the earth?
8th April 2013, 08:46 PM
Legendary
Mud has been guilty of many offences
8th April 2013, 08:53 PM
How's the serenity
Pretty sure there is a welcsh plug in an oil journal on the back left side of the zd30 block . This may be your culprit . either way box out and flywheel offski . $$$ . sorry .
8th April 2013, 10:46 PM
Legendary
The seal is worth around $60 from Nissan and i'm not sure if you have an Auto or Manual?? If you have a man it might be a good idea to do a solid mass flywheel and new clutch while your at it aswell, coz you will be paying around $650 - 1k in labour anyway!!
