Results 1 to 8 of 8
Thread: Led light help
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Led light help
    Hi all, have changed almost every single light on my gq patrol to led bar the headlights and the little ac button. But now when I put my foot on the brakes the dash lights/Parker lights light up for a split second. It only started happening when I changed the dash lights and center console lights to led, so I'm guessing its some sort of current draw issue. I never really wanted to put load resistors in because I like the idea of less current draw with the LEDs, but do I have any other options here?
    Andy
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Your problem will be a back feed from your stop and tail light LEDs.
    Try putting a blocking diode in series with each.
  4. The Following User Says Thank You to Yendor For This Useful Post:
    Parksy (30th March 2013)
    Patrol Guru Airstrike's Avatar
    Feb 2011
    What did you use for the console LED and can you post pics of the console lit up at night. I have been thinking of doing the same after I did the dash.
    Expert WYLD333's Avatar
    Nov 2012
    Pakenham
    yup a simple diode in the system will stop any back feed
    Jan 2013
    Nowra NSW
    5 Post(s)
    Cheers yendor, will give that a go.
    Mine is a gq airstrike. The center console is just a t10 fitting. Will grab a pic tonight.
    Jan 2013
    Nowra NSW
    5 Post(s)
    Should have asked, which lights should I put the diodes in? The brake lights or all the dash/console/Parker lights?
  9. #7
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    You will need to put a diode in the park light and stop light circuits at each tail light.
  10. The Following User Says Thank You to Yendor For This Useful Post:
  11. #8
    Jan 2013
    Nowra NSW
    5 Post(s)
    Here's a pic of the dash and console. I only used white LEDs as I didn't want to mess with the green dash filters. Basically looks the same as before just alot brighter.
  12. The Following User Says Thank You to Parksy For This Useful Post:
    Woof (30th March 2013)
