30th March 2013, 03:09 PM
Suspension lower on one side?
I got ironman foam suspension kit that's 6 months old roughly - noticed the other day that the rear left sits about an inch or so lower than the right.. Anything I should be concerned about?
Black Irish with an English twist / Gypsy / Tattoo's and loaded full of Grumpiness.. I blog my paintings and other random bits on
Billy Bleed
30th March 2013 03:09 PM
30th March 2013, 03:12 PM
btw I'm getting a service in two weeks.. Is it an easy fix or something that will cost $$?
are these adjustable etc?
Billy Bleed
30th March 2013, 03:17 PM
How's the serenity
Its an easy fix with coil spacers .
The price of excellence is dicipline , the cost of mediocrity is dissapointment .
30th March 2013, 03:22 PM
coil spacers are a cheap fix to a problem that will still be there and wouldnt fit them to any car. Has your car always been like this or is it something that has just happened?
30th March 2013, 03:54 PM
I don't know as I purchased the car about 3 months ago.. I have only just noticed it when up at my dads place..
The suspension and springs were fitted before I purchased the car..
Billy Bleed
30th March 2013, 04:02 PM
U may have to have a look at the springs and make sure they have been fitted on the correct sides, u have L/H and R/H sides and if fitted ass about will make your car lean as one side is shorter than the other.
Hope its just a simple fitment error or you may have to throw some new spring in it mate
The Following User Says Thank You to WYLD333 For This Useful Post:
30th March 2013, 04:11 PM
Re: Suspension lower on one side?
Had to put a spacer in my GU with iron man springs. It does the trick but i guess they aernt the best quality out there.
Sent from my GT-S7500T using Tapatalk 2
30th March 2013, 04:39 PM
Ill point it out to the mechanics and see what they suggest..
If I kept the iron man shocks would it be worthwhile updating the springs with a better quality brand?
Or is this something I should be doing as a complete refit?
How much (ball park) does it cost to replace with a new system with a decent product?
Billy Bleed
30th March 2013, 04:43 PM
You have left and right hand springs to compensate for weight of the driver. easy enough fix if thats the problem
30th March 2013, 04:49 PM
I'm thinking the PO did the lift himself.. Hopefully it's a simple fix so I can spend my cash on more fun stuff..
Billy Bleed
