20th March 2013, 05:55 PM
primus fridge 12v power cord
hi, today i bought a 45l mammoth fridge. the 12 v power cord has a cig lighter plug on it . im just wondering what everyone does if they wanna run an Anderson plug instead? do they just cut the cig light plug off and hook up a andersen plug? or is there somewhere i can buy a dc cord with Anderson plug already on it?
any ideas would be awesome
cheers Corbin
Sent from my GT-I9100 using Tapatalk 2
20th March 2013 05:55 PM
20th March 2013, 06:00 PM
Hardcore
Just chop it mate that's what most do
IF ITS NOT BROKEN IT MUST BE A PATROL
20th March 2013, 06:02 PM
Just looking into this atm, Engel have a plug and socket that you push/twist to lock. Can never come loose.
Which I presumeis why you doing it ,If just dedicated for Fridge ,Anderson is a great option IMO. Running off Aux via
Thermal fuse 12v.
Edit will cost you heaps premade
20th March 2013, 06:04 PM
Moderator
I have cut the plug of my Weaco and my Engel in favour of an Anderson Plug.
CHOP IT!
Check out my Toy -->
Rogue Dung Beetle
20th March 2013, 07:01 PM
yep sounds good ill give it the old chop chop when my anderson plugs arrive,
whats a thermal fuse? do i need another fuse as there is one built into the fridge already?
cheers
20th March 2013, 09:03 PM
Patrol Freak
I would splice some wire in to use either plug, obviously covering up the cig plug if using the other so as to avoid a short, at least this way if you ever need to use it in another car etc, you can.
cheers.
20th March 2013, 10:32 PM
Re: primus fridge 12v power cord
trekster
cheers.
good idea ill keep that in mind
thank you
21st March 2013, 12:04 AM
I have the same fridge and I just cut and shut mine as it already had a heavy cable to the battery.
21st March 2013, 12:39 AM
Moderator
trekster
cheers.
to get around this i then used the plug i cut off paired with another anderson plug to make an adapter to reattach when needed Works a treat and gets stored in the pocket of the fridge transit bag.
Rogue Dung Beetle
21st March 2013, 02:06 AM
Patrol Freak
As others have said - cut it off and crimp/solder in an Anderson. Another option is to cut it off - put a connector on for either a ciggie plug or Anderson depending on when/what you need. Andersons though are the best connector mate.
Jas
__________________________________________
Roads? Where we're going we don't need roads.......
2012 Silver GU 8. Bullbar, Warn XD9000 winch, snorkel, towbar, roof bars and rack, awning, 33" Mickey Thompson ATZ 4ribs, 2" lift - Dobinsons coils and Koni shocks, more to come......
2013 Travelling Wilbury's Cape York Trip - bring it on!
