Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: HELP, what can it be
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    One for the gurus, and that certainly ain't me.
    Last week or so when I hit a decent bump, have noticed oil light flickering and on the weekend my sub tank light came on with 1/4 tank left.
    Today I jumped in the car after work and kicked the ol girl over, sounded like she was struggling a bit, Didn't fire and on 2nd attempt nothing at all, no dash lights no nothing, had a look and a play with the fuses and what ever looked electrical and noticed a clicking and buzzing coming from some blue relay looking thingy in the fuse compartment (top left) in car, pulled it out, put it back(looked fine) played with a few more wires under the bonnet. And still nothing. Played with the key a bit and radio came on, tried a few more times and away she went. Drive home and switched Trol off and then tried to start again and nothing.
    Now I'm a bit of a dumb azz when it comes to electrics, so heading outside to clean terminals etc, so what else to look for is beyond me, so any ideas from anyone would be appreciated.
    Wish me luck lol
    Cheers Pete
    TAPPN OUT
    "Tonka Tuff" 08-GU6, 3.0lt crd, 5 Speed, Turbo Diesel, Hpd, Arb, Ome, MT Baja Atz.
    Legendary Alitis007's Avatar
    15 Post(s)
    Try pulling off the ignition switch on the back of the ignition barrel and have a play with it, it could have become loose with age.
  4. The Following User Says Thank You to Alitis007 For This Useful Post:
    wildgu6 (20th March 2013)
  5. #3
    .......... TPC's Avatar
    63 Post(s)
    Do you have a multimeter to check the voltage?
  6. #4
    Sep 2010
    Adelaide S.A
    No for that one, tried one out once upon a time and couldn't work it out, only elec thingy I got is a test light.
    TAPPN OUT
  7. #5
    Do you have a heap of keys on key ring.???
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #6
    63 Post(s)
    I had a crack in a terminal clamp on my Aux battery that caused a big voltage drop, battery was fully charged but dropped 2v through terminal clamp connection.
    Check battery clamps and earth connections.
  10. The Following User Says Thank You to TPC For This Useful Post:
  11. #7
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Start by removing both battery terminals and give them a good clean.
    Also check the main earth lead thats runs from the negative post of the battery down to the inner guard and engine. Make sure it's not corroded or broken.
  12. The Following User Says Thank You to Yendor For This Useful Post:
  13. #8
    Patrol Freak
    Sep 2011
    adelaide
    18 Post(s)
    Had a similar problem with GQ petrol turned out to be a fusible link but hey I see your in the good hands of the Guru Yendor
    Hope its sorted easily mate
  14. The Following User Says Thank You to pearcey For This Useful Post:
  15. #9
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    I'd be looking at earthing problems after the fuses.
  16. The Following User Says Thank You to NP99 For This Useful Post:
  17. #10
    Sep 2010
    Adelaide S.A
    Fingers crossed guys, thanks for the advice, as said am a dumb azz with electrics.
    Pulled off batt term's and gave good clean and spray, and all elec connections, checked ignition connection but ok.
    Batt was a bit dry so topped up and put on charge for an hour while doing other bits, needs longer but time not on my side, will get back to that, by the way do I need to disconnect batt to charge, did so but as it still needs charge ?? Do I need to disconnect again. Would be really good if I didn't have to, light and elements as well as location does help me ATM
    Anyway tried the ol girl and she fired straight away, tried several times with a break in between and so far all good.
    Big test will be cold start at 4am tomorrow. Thanks again guys, much appreciated.
    TD I don't have jail house keys mate, only 1/2 d, not a lot of weight if that's what your thoughts were??
    TAPPN OUT
