Results 1 to 2 of 2
Thread: Wiring a turbo timer to a GU 3litre Patrol
    Unhappy Wiring a turbo timer to a GU 3litre Patrol
    Hi Guys: I have just built a Turbo Timer kit from Jaycar electronics. It is called an Adaptive Turbo Timer and appeared in Silicon Chip Magazine in 2007. Kit no. KC5451
    The timer monitors engine load through the MAF sensor and determines how long the turbo must run at cool down.
    It all seems to work, and is adjustable for maximum cooldown and sensor input, and you can monitor it's progress via 3 leds. It is supplied with extra outputs to operate another relay to defeat the immobiliser when you turn off the ignition to allow the cool down idle.
    There is a couple of senarios of how to wire it in but it is a general kit for all makes and models and I need a bit more detail to accomplish this task in my 3l GU.
    I have tried a couple of wires after consulting the Nissan wiring manual but so far no success.
    Any help or direction will be greatly apreciated.
    Wasso, WA
    How's the serenity boots's Avatar
    Sep 2011
    The price of excellence is dicipline , the cost of mediocrity is dissapointment .
