19th March 2013, 12:58 AM
When i had my TB42e i had problems with the idle as well, nd i played around with it a fair bit, there is a special way to do the idle adjustment if i can remember correctly, defenitly set the TPS to 0.4-0.45 first cause that rectifies the smooth change of the auto,
then u have to disconnect the plugs on the idle control valve, its where that black screw is, aswell as the TPS plugs ,should be 2 plugs on either one,
start the engine, adjust the idle up, by whinding the screw out i think, turn the engine off connect all plugs, start it up again, the revs should drop, so just keep playing around with the idle followin thos steps, im not saying that its the problem but its worth a try,
another thing it might be it the MAF sensor, disconnect while the engine is running if no change it could possibly be it aswell, if a vacum leak grab a tin of WD40, while its running spray all over hoses, down beside the inlet manifold, just hope its not a manifold gasket lol, pain in the a**
Hope u figure it out mate
Scott
The Following User Says Thank You to saw13 For This Useful Post:
zmaster (20th March 2013)
19th March 2013 12:58 AM
21st March 2013, 12:07 AM
Thanks for the brilliant response, I was also thinking temp sender,will measure the TPS and IAC, have ECU Talk, and laptop, temp seems to be reading fine, not sure how high it should climb, can't remember the TPS sensor reading, but the oxy sensor seemed lazy, so I'll change it out for a new one. Other issue I forgot, on stabbing the acc pedal, revs jump up to say 1500rpm, then lazily drop down to 1100rpm, before eventually dropping back to 950rpm.
21st March 2013, 12:34 AM
High idle TB42E
zmaster
From my experience that is definitely a vacuum leak so the motor is sucking air from some where, oxy sensor will make it run lean or rich @ NOT
21st March 2013, 09:50 PM
