19th March 2013, 07:48 PM
#21
Re: GQ Head Cracks?
nissannewby
It's a petrol. I diesel head is near flat and doesn't have a spark plug poking out.
Tooshay.. good pick up.. missed that small detail.. lol
So, skim away, just don't overdo the boost..
Owner of
Westy's Accessories
19th March 2013 07:48 PM
20th March 2013, 02:49 PM
#22
Just got the call from the head shop, it pased the pressure test so no cracks but they said it was bent? First time I've heard of that but anyway they straightened it and faced it for $220 so will pick it up tomoro morning. Might have it going by the weekend if i can find gaskets tomoro as well.
'93 GQ currently with zero additions
'83 MQ with 308 conversion, for sale.
PowerSlideRacing.com.au
20th March 2013, 03:01 PM
#23
Didn't you say you did the warp test and it was fine?! Would be good to avoid facing, if you can.
20th March 2013, 03:07 PM
#24
GQ Head Cracks?
The head warps when the head bolts loose tension then from the heat and pressure of the motor working it bends like a banana. They sound like the job is getting done correctly and by them facing it they mean machining a few thou off (thousandths of an inch)
20th March 2013, 03:10 PM
#25
GQ Head Cracks?
Don't forget to oil the head bolts with 10w30 motor oil, just wet your hand and wipe run your hand across it ( you should have plenty of practice doing that from your early teens lmao ;-p )
The Following User Says Thank You to Alitis007 For This Useful Post:
BigRAWesty (20th March 2013)
20th March 2013, 03:14 PM
#26
Did you check ellipsis of cylinders? It can be problem for high mileage engines.
I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
20th March 2013, 05:09 PM
#27
Re: GQ Head Cracks?
Wine_maker
Do you check ellipsis of cylinders? It can be problem for high mileage engines.
???? What of the cylinders?
Owner of
Westy's Accessories
20th March 2013, 05:18 PM
#28
Roundess of the bores, no i didnt check it as i just want to get it going and hit the dirt. I'd rather do a v8 conversion than rebuild the stocker anyway.
The Following User Says Thank You to PowerSlide Racing For This Useful Post:
Wine_maker (20th March 2013)
20th March 2013, 05:22 PM
#29
21st March 2013, 02:21 AM
#30
Alitis007
Or during breakup and rekindling time. )
