16th March 2013, 12:29 AM
Patrol Guru
What to believe
I run an ecu talk all the time, the speed on the ecu talk is about 5 km per hour slower than the speedo... I have 305,s on the troll, I follow the ecu but do you guys reckon the ecu is accurate or the speedo?
Scotty
16th March 2013 12:29 AM
16th March 2013, 12:41 AM
Re: What to believe
Grab a GPS to confirm. Guessing it 5k at highway speeds?
Owner of
Westy's Accessories
The Following User Says Thank You to BigRAWesty For This Useful Post:
rottodiver (16th March 2013)
16th March 2013, 12:47 AM
Patrol Guru
What to believe
Yeah at 100km/h on speedo it is 95 on ecu talk..... Yeah good call on GPS.. Probably should have thought of that... Lol
16th March 2013, 12:50 AM
What to believe
I'm running stock wheels and my speedo is out for eg speedo 50 = 50 gps, 60 = 58, 70 = 65, 80 = 75, 90 = 83, 100 = 90 and 108 = 100 @ 1850rpm, also when i put it on my ultrascan scan tool i noticed in the ecu it had speed variation ( or something along those lines) 5km/h
16th March 2013, 01:39 AM
SUCH IS LIFE
Re: What to believe
Try a GPS to compare mate
.........on the move
________________________
______ 2017 D-Max _______
16th March 2013, 06:17 AM
Hardcore
The readings 007 gave sound typical, it appeared to me like the GU speedos read well below actual speed, (100kph group tested with GPS) fitting 33s often saw a more accurate speedo reading at 100kph.
On a unrelated topic, can you put up some pics of your car with the 305s please Scotty ?
16th March 2013, 07:40 AM
I had exactly the same with my GU and stock tires - 120 on Speedo was actually 108 by GPS. Fitted 33s and 120 on speedo is 118 on GPS - much better
Having said that - the Odometer now under reads slightly.
Checking elapsed mileage with GPS shows that the ODO is not counting the KMs accurately - it's under reading. I can't remember the exact difference but it's noticeable. I'll check and post up later.
Steve
2011 Patrol Safari 4.8 (Fitek)
16th March 2013, 07:43 AM
#8
I run 305s and find I need to travel at about 98 by the speedo to sit on 100 by GPS,
16th March 2013, 08:43 AM
#9
I have exactly the same problem on my GR/GU, its speedometer is in miles per hour, I've checked it against GPS and is about 10% low at most speeds, So when I am doing indicated 60 miles an hour, actual speed is about 54mph - the only good side of this is at least I won't get a speeding ticket, even if I'm fractionally over the indicated speed limit
16th March 2013, 08:49 AM
#10
The 747
Re: What to believe
My last GQ was spot on with 33s.this one is way off, 90km on the speedo is really 100km on gps
If you're happy and you know it tap a post!
