Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: are 33" tyres legal in Vic?
    Nov 2010
    hi,
    still looking at what muddies to get for my GQ. I'll be doing a 2" lift so I'm looking for 285/75 R16 or 33" tyres. They are very similar sizes, but I keep seeing posts on the internet saying 33" are not legal? Is this the case in Vic? If so why? They are the same size as 285/75. There are many more 33" available than 285/75 which would seem strange if they are not legal!! Thanks for any advice.
    1981 Nissan Patrol MQ SWB, 3.3TD, West Melbourne.
    581 Post(s)
    Hi mate, I am 99.999999999% sure that 33's are legal in Victoria.
    Hopefully someone else can make it 100%...haha
    Nov 2010
    just done a bit more reading around. There's a lot of talk about a 15mm rule, ie. you can only go 15mm bigger (and +2% variance) diameter than the tyre placard in your car. My GQ says 265/70 R16 = 777.4mm so I could get up to 807.95mm (31.8") if this rule is correct. That would include 285/70/16, 265/75/16 and 285/75/15.
    I don't seem many fourbys driving on stock tyres, most are at least 33". It would be hard to believe that they are all illegal???!!
    Nov 2010
    I don't believe they are. Refer to Part 8 of VicRoads Guide to Modifications.
    http://www.vicroads.vic.gov.au/NR/rd...340/0/VSI8.pdf
    My GU is placarded at 265/70/17 (777.4mm dia). This even makes 265/75/16's (803.9mm dia) illegal!!! Totally rediculous.
    33" is the general "rule of thumb" for legally acceptable tyre size however an insurance assessor who was right on the ball may pick them as a voidable modification. Crazy.
    265/70/16 = 777.4mm (30.6"). This is the placarded tyre/rim size for my GU.
    265/75/16 = 803.9mm (31.65"). This equals 26.9mm bigger than placard or 11.9mm more than max 15mm increase.
    285/75/16 = 833.9mm (32.83"). This equals 56.9mm bigger than placard or 41.9mm more than max 15mm increase.
    305/70/16 = 833.4mm (32.81"). This equals 56.4mm bigger than placard or 41.4mm more than max 15mm increase.
    wow, what an mazing find, thanks for that. So basically, you can not legally change the tyre size on your vehicle from that stated on the placard because the next size up is always greater than 15mm difference . So it raises the question, of the 90%+ 4x4s out there with bigger tyres, has anyone had an insurance claim rejected??!!!!
    With the suspension height, it seems to read that as long as you don't increase the distance between the bumpstop and the axle by more than 1/3, they you can go as high as you like? But then it goes on to say in sections 6, that any modifications to suspension requires an approval certificate. So basically you can't change anything to do with wheels or suspension!! So nearly every 4x4 on the road is illegal. Or did I read it wrong?
  6. #5
    ilikedonuts_10
    Guest
    Hi,
    I have a 2" lift on my GQ and with 33" tyres the guards look like they are getting pretty close to grating on the guards. Does anyone else have this or is this ok?
  7. #6
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by boggy2006 View Post
    Not sure about other states mate, but the guidelines for modification covering tyre replacement in Queensland are the ones that note no greater than 15mm increase in diameter ... as you no doubt saw in the threads, ridiculous guideline when put in context of the others that you have to obide by ... are you in Queensland? If so and you want a copy of the guidelines, PM me with your email address and I'll shoot them through ...
    Scotty
  8. #7
    Nov 2010
    thanks, I'm in VIC so have those guidelines now. It's so rediculous. Looks like a grey area, but you could get screwed with a big claim. I mean, how many cars are on the road either raised or lowered, I bet not many have engineering certificates. And tyres as well. Yep, "just car insurance" will insure you for any mod that's legal, yet the next tyre size up is not even legal, so technically you are not insured!!
  9. #8
    Beginner JimboGQ's Avatar
    Oct 2010
    Western Australia
    Mate, any grey area should be treated with caution if an insurance company is involved as they will look for any loophole not to pay for a claim. It is always safer to go the extra mile than try and risk it as the buggers will always try and get out of paying a claim.
  10. #9
    Nov 2010
    hi, I asked the question to Vicroads and got an interesting reply. They attached a document called "Vehicle Standards Bulletin 14" and quoted it as stating that for 4x4s you can increase the diameter of the tyres by 50mm above what is on the tyre placard. It also mentions about 50mm suspension and body lifts. Is there anyway I can attach the whole pdf document here?
  11. #10
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Go Advanced in your Post and click on Paper Clip (Attach File) and go from there
