Results 21 to 30 of 36
Thread: Rattle or Vibration. 4.2 turbo.
    Patrol Guru
    May 2011
    mackay former alice boy
    Very common mate with the 4.2. Mine harmonics through engine and gearbox and exhaust.
    It's just the awesome power of the td42 wanting to get off road rather than the black stuff!
    Patrol torque rattle just too let you know your'e in the 4.2 and not a toy ota from idle to 950 rpm on the flat ENJOY IT HAS BALLS
    Jan 2018
    yep low rpm on 1st or 2nd gear TD42t club signing in.
    Gear roll over. Gearbox chatter. Whatever you want to call it. Its the sound of the TD42T doing its thing lol!
  4. #23
    109 Post(s)
    Quote Originally Posted by drgtr View Post
    Haha yeah when you get used to it you grow to love it! Was interested to read exactly what caused it though as I never really knew exactly why they do this.
    Does anybody know what the factory original clutch is in the Y61 TD42T?
  5. #24
    Jan 2018
    All I know is all TD42Ti come with Solid Mass flywheel from factory.
    They are big like truck gearboxes so its normal. No ill effect. Most have it and through their life its all good.
    Just embarrassing at times haha.
  6. #25
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Mine makes this noise as well...
    Is there any way at all you can stop it making the noise, by adjusting the harmonics or anything? Would replacing the clutch and all gear oils help at all?
    Td42 coily
  7. #26
    Jan 2018
    Quote Originally Posted by JackoGQYoot View Post
    Honestly I have read every single thread and post on the internet I can find.
    I would say no. Its a normal thing due to the design and nature of the massive gearbox.
    there is no detrimental affect at all. Just embarrasing at times but you get use to it lol
  8. #27
    Oct 2017
    WA
    What actual components is it that are rattling?
    Td42 coily
  9. #28
    22 Post(s)
    It's called gear rollover. It's the gears themselves meshing under little to no load. Give it some load or rpm and it goes away.
    96 GQ coil/Cab
    08 G6eT
  10. The Following 3 Users Say Thank You to Ben-e-boy For This Useful Post:
    Hodge (4th April 2018), JackoGQYoot (4th April 2018), mudski (4th April 2018)
  11. #29
    464 Post(s)
    Its strange how this is more prevalent with the TD's. My ZD never had this, even with a SMF. Now with a TD, using all the ZD running gear still, I have this same rattle. But strangely enough, I like it.
  13. #30
    22 Post(s)
    It could be due to the odd firing order and shear rotating mass of the TD, but I dont really know.
    96 GQ coil/Cab
    08 G6eT
  14. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    MB (4th April 2018), mudski (7th April 2018)
