8th March 2013, 07:24 AM
Change Solenoid for engine shut down TD 42
Hello Mates,
My engine does not shut down properly and shutters like crazy on shut down. The only way I can shut it down is by putting it in 5th gear and letting out the clutch while holding the brake.
I have heard this is a bad solenoid that can be changed to fix the problem. Where may I purchase this "solenoid" and is it easy to replace?
Thank you,
Kristofer go
8th March 2013 07:24 AM
8th March 2013, 05:05 PM
Mine dose it too. Found that when it happens if I floor the accelerator pedal it will shut down. Also been told it could be the timing.
8th March 2013, 06:18 PM
Yo Jando that doesn't sound like its doing the motor any good.
big gutful of fuel on shutdown?????
8th March 2013, 06:43 PM
Not really a gut full of fuel. The key is off, so none to get past Solenoid. Just getting rid of what’s in injectors. I think, maybe a dripping injector, not 100%. I thing better than staling it.
