Results 1 to 9 of 9
Thread: Exhaust brake
    Jul 2010
    Waterford West Qld
    Exhaust brake
    Not that it's high on my agenda, many other things to do first. But is it possible to install an electric exhaust brake on an SD33T? I see this as a handy safety device for towing. And no I am not talking Jake Brake. And would anyone actually know a ball park price for one?
    Now I will await the in depth open discussion with all of you
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I think it would be very funny hearing the sound of a trucks jake brack coming out of a patrol *L*
    My in depth discussions is: sorry can't help you on this Tim
    Aug 2010
    17 Post(s)
    Tim, i shall see my old man 2morrow and ask him what he thinks, he is an ex diesel mechanic and might be able to shed some light
    Aug 2010
    17 Post(s)
    Tim, this is the reply i got from my old man, hope it helps in some way
    Cheers, Todd
    Yes you can fit an exhaust brake to any diesel. As far as I know no one makes an electric one. Most of the larger trucks use air pressure, smaller trucks could use vacuum.
    There is not much stopping one from using an electric solenoid to operate the exhaust brake as long as it has enough power to pull it closed (to over come the return spring and the exhaust pressure against the butterfly).
    You could by one from the truck wreckers or Smiths Exhaust brakes here in Sydney.
    http://www.gearingdynamics.com/exhaustbrake.htm
    A vacuum open & close butterfly type for small diesels (Toyota Nissan etc)
    http://smartbrake.com/
    This is a slide gate type
    http://www.sgvaustralia.com/
    Slide gate type (previously known as Smiths)
    There is still a bit of debate as to where to fit the brake some say before the turbo and others after. Most are fitted after (easier).
    When you accelerate after using the brake there might be a bit of turbo lag. You would have to disengage it just before you wanted to power on. It is something you would get use to.
    Jul 2010
    Waterford West Qld
    cheers Todd.
    Thought I would have caused a bit more debate with this one.
    Aug 2010
    17 Post(s)
    No worries Tim, I knew my old man would have something to say about the topic
    Still think a jake brake would sound nice on the Patrol *L*
    Aug 2011
    Oakey - NW of Toowoomba, QLD
    Hi mate - Nissan actually make a vacuum operated exhaust brake for their light trucks/buses. Bear in mind that to do well you will need the following :-
    1. Accelerator switch (normally closed when pump is coasting) on the fuel pump ($194 - ex Japan) turns OFF brake during acceleration
    2. Clutch switch - (normally closed) turns OFF when clutch is depressed
    3. Operating switch/lever (obvious)
    4. Vacuum supply, and
    5. Electrically operated Vacuum relay to operate the brake unit.
    Have no idea how much all this would cost to set up, but check out the truck wreckers.
    Cheers, Loito
    PS Can probably help out with diagram for the electrical side of things
  9. The Following User Says Thank You to loito For This Useful Post:
    Finly Owner (18th August 2011)
  10. #8
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by loito View Post
    Cheers, Loito
    will keep this in mind, thanks for your knowledge. I do have other things i need to do first, I am just gathering all my info for my thoughts to be indexed.
    Tim
  11. #9
    Expert the godfather's Avatar
    Mar 2011
    Piara Waters, WA
    Hi Tim, Like everyone else I cant see a problem with this. But what is to note is that on a truck the position of the exhaust brake is critical. So you cant just wack one in. You need to know where to put it. So it may require some math.
  12. The Following 2 Users Say Thank You to the godfather For This Useful Post:
    Finly Owner (19th August 2011), Mrowka (20th August 2011)
