3rd March 2013, 05:57 PM
ZD30 Reconditioning vs Second-Hand Engine
Hi guys, Shonky here,
Theo the patrol has had a pretty rough life starting out as a mining vehicle for its first 130000 K's. We almost came to the point of trading the old fella in for a newer model Kluger or Territory but came to our senses and realised we'd only be downgrading.
The Mrs gave me the all clear to put in a TD42 in but my excitement was dashed pretty quickly after a phone call to Patrol-A-Part informed me that the engine i want to put in the 08 model could not be registered so was therefore illegal.
My new plan is to either have my existing engine reconditioned or look for a lower K's engine that has been trashed as much.
My question for you guys is what will give me more benefit in the long run? The money issue wont be a problem, I'd rather spend the cash to do it right the first time. I have plans to put in a custom Roo System diesel chip and 3" exhaust to help with fuel economy as well as a new 2" lift kit to help with its sagging issue.
2008 Nissan Patrol GU 6 DX 3.0l and proud of it!
WARNING: Using a Snatch Strap on a Tow Ball can KILL PEOPLE!
3rd March 2013 05:57 PM
3rd March 2013, 06:32 PM
Im pretty sure a Duramax will fit, check the archives
4th March 2013, 05:17 PM
Im looking for more fuel economy so im not too sure if that will help me out. I wouldnt even begin to know how much a duramax cost let alone where to buy one or install it
4th March 2013, 05:29 PM
Why do you want to replace the engine? is it not running or down on compression?
4th March 2013, 05:38 PM
Moderator
put it on a Dyno after the exhaust is done, tune it right and fit the chip and drive her until she spits a bearing!
Check out my Toy -->
Rogue Dung Beetle
4th March 2013, 06:23 PM
Second hand - Depending on where or who you get it from, may be worse then what you have. (Be sure to read fine print from wreckers etc)
Reconditioned - Pricey however alot less stuffing around and the car will not be off the road as long (Warranty 3-12 month pending on where you go, Still read fine print...It may be warranty, however some do not cover costs involved)
Reconditioning your motor - Car will be off the road for a while, can be cheaper then a second hand engine pending on how much work it needs.
My 2 cents,
Need prices? give me a email on what your looking at or everything if your interested.
Regards,
Rob
