Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: hey guys, thought i'd say gday in here as i just joined up
    Beginner MadDan's Avatar
    Feb 2013
    as my super original forum name illudes to... Dan is my name.... (got the nickname from riding sportsbikes when i was younger and it's stuck)
    onto my second patrol now, had a 2002 3L all set up with a 6'lift with all the good gear but in a family rescue attempt (long story) tackled water a little deeper than i should of and it conked out (lesson learnt, now have a snorkel)
    aaaanyways, this lead me to my current patrol, a 2005 st-s 3L , picked it up ex lease from a copper in darwin
    bought this one mainly cause i want to set up a good tourer to eventually do a cape trip then run through to the kimberlies, still like playing hard at times tough so want a versitile setup
    list of goodies are as follows:
    standard steel winch bar with 12k winch
    3 lightforce genisis spotties (one spread 2 spot) with 70Whid's installed
    70W hid headlight conversion
    2'lift with airbags in the rear
    33' mtz's
    twin long range tanks (once you've had a long range tank... it's hard to go withough... LOVE not needing to fuel up for a month, 1500k's per tank on average)
    ARB twin wheel rear bar with genuine nissan rims
    have a nice stereo setup inside with a double din jvc headunit and a good speaker/sub setup
    uhf gps all that stuff
    have just recently had my motor die on me (no 2 piston blew a hole in it driving along the highway at 90k's an hour!) so new reco'd motor going in with hardened pistons, catch can, dawes valve, needle valve
    while i'm at it i'm putting a cross country intercooler (stock intercooler was i think to blame for my issues as it was badly split) aswell as a taipan exhaust and chip
    anyways, i'll update this later on as i'm a little peeved at my car at present because i've just got everything back in and started it up only to discover that my injector pump isn't drawing fuel by itself... but i'll sort that out hopefully
    cheers guys... and thanks to those that have already responded to my thread in the mechanical section re: pump issues
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    welcome mate good bunch of guys here eager to lend a hand, nice setup you got there sounds like a good tourer.
    goodluck with the injector pump and enjoy the sight and sounds of the forum
    CERTIFIABLY INSANE Drewboyaus's Avatar
    Oct 2011
    Essendon
    Welcome to the temple of Patrolology!
    Great forum here with a stack of good people to help out when you need it....
    Tip tip tip......tap tap tap....
    1997 GQ Patrol RX, TB42E. Mods: OME 2" lift, 33" BFG KM2'S, ARB winch bar & reconditioned X9 Superwinch, IPF 900 spotties HID conversion, ARB side steps and scrub bars, Kaymar rear step & spare wheel carrier & jerry holder, Rear 55W LED worklight, Safari Snorkel, 147L LRA tank, Extended diff breathers, dual batteries, GME UHF, Home built drawer and fridge slide, ARB 60L fridge.
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Re: hey guys, thought i'd say gday in here as i just joined up
    Welcome mate. Enjoy the patrols.
    Sounds like you have a quite capable bus there.
    Owner of
    Westy's Accessories
    Feb 2013
    thanks guys.. yea my rig goes alright.... when it does actually GO!.... grrrrrr... lol
    still surprised how many places i can go with just a well set up 2' lift compared to the full blown 6' lift i used to have (snake racing drop arms and the works) just need a little more ground clearance under my long range sub tank as it sits about an inch under my chassis rail
    plan to go to a 3 inch setup with superflex arms and 35's down the track.... but that's down the list of priorities (just bought a house and got engaged... if you know what i mean ;-)
    keen to get it running again and see how much difference the cross country intercooler, taipan exhaust and chip make, along with the dawes and needle valves looking after the turbo and removing that annoying blip in the revrange at around 2500 rpm
    i reckon i was down on power with this rig before hand as it has less power runing 33's than my old 3L had running 35's! so am expecting a good %30 increase in power (leaky intercooler being the biggest culprit in lost power i suspect)
  7. #6
    Feb 2011
    Shed
    45 Post(s)
    Gday Dan welcome aboard nate gotta friendly mob here fulla great info and advice
  8. #7
    Thomastown, Melbourne
    6 Post(s)
    Welcome aboard mate........
  9. #8
    SUCH IS LIFE Maxhead's Avatar
    ACT
    G'Day and welcome to the forum mate
    ________________________
    ______ 2017 D-Max _______
  10. #9
    Welcome to the forum, Enjoy
  11. #10
    Expert Dominator's Avatar
    Oct 2011
    Welcome mate. If you have not done it already I strongly suggest fitting a boost gauge and an EGT gauge.
