10th February 2013, 11:24 PM
Wobbly gear knob
Hey folks,
Driving back after a weekend away, suddenly gear knob is really loose! Can still get into the correct gear and it doesn't drop out of gear, so guessing there is some kind of 'plate' that the gear knob sits into, which guides it or gear selection .... And guessing this is broken/missing..... Anyone had this before? And fixed themselves?
1997 GQ LWB ST 2.8td manual 415,000km
Trace
2006 GU ST 3.0td manual. CTEK 250S Dual Battery - Ironman 65L Ice Cube - Pioneer AVH-3600DAB - Tough Dog Adj 45mm Shocks, springs and HD steering damper - Airtec Snorkel - King Brown 3" exhaust
10th February 2013 11:24 PM
11th February 2013, 12:57 AM
Wobbly gear knob
Sounds like the gearstick bushes has died. I believe that you can remove a plate from inside the cab on some vehicles under the shifter boot and remove the gear stick and replace the bush. But honestly not sure on patrols I did it to a mates Mazda 808 and it was a piece of pi$$ maybe pull the boot up and have a look you may also be able to shift gears from there if you really have to otherwise check the workshop manual out
Just tap it in just tappy tappy tappy
11th February 2013, 07:47 AM
Yeah, under the boot theres a series of bolts holding top cover plate.
remove that you'll see nylon bush etc that needs to be replaced
11th February 2013, 08:04 AM
The Following User Says Thank You to Parra For This Useful Post:
Bloodyaussie (11th February 2013)
11th February 2013, 08:42 AM
Parra
As above an easy fix with this part...
11th February 2013, 08:48 AM
threedogs
Dont even need to go that far mate. Its just a circlip holding the stick in and theres a nylon bush that comes out with the stick...
11th February 2013, 10:13 PM
Awesome - thanks all
Will check it out ASAP and let you know how we go
2nd March 2013, 03:38 PM
Hey All ......
Just replaced the bottom bush and the top bush (official Nissan parts from Nissan Garage as per above) and the boot (which was totally fallen apart) .... and it's still wobbly
Any more ideas?
Is it likely to be the spring that sits under the top bush?? Or something further inside the gearbox?
Help!
Trace
2nd March 2013, 10:32 PM
Wobbly gear knob
Yeah when I replaced both my bushes it got tighter in 1st, 3rd and 5th but is still wobbly in 2nd, 4th and reverse. Have never worked out what is going on. Just leaned I live with it.
Sorry I can't help.
3rd March 2013, 12:00 PM
Wobbly gear knob
Might be a linkage or selector fork problem for that you'll have to remove the gearbox. I suggest you go see a gearbox specialist and tell him what's going on and that you've replaced the bushes and see what they say
