Results 1 to 9 of 9
Thread: GU Spanner & socket sizes
    Ballarat, Vic
    174 Post(s)
    Just a quickie.
    What is the largest size needed in a GU Patrol toolkit?
    A Nomadic Life (Blog)
    Expert Lieney's Avatar
    May 2012
    Adelaide,SA
    All depends on what the purpose of it is I guess.
    Local treck on a weekend, or self-sufficient drive across central Australia?
    I carry a ring/open spanner set (6-19mm), plus a 300mm shifter, a wheel brace & a decent sized hammer.
    Yendor might be able to give a more accurate answer depending on what you want it for.
    06 GU IV Nissan Patrol wagon 3.0L, Tough Dog 2" lift, Xrox bar, 12k Mako winch, 33" muddies, 3" exhaust, Awning, UHF, drawers & fridge, custom sliders, DVDs, custom water tank and pump, rack etc etc.
    Now just in - GQ Shorty 4.2 petrol, UHF - but looking at turbo or V8 conversion
  4. The Following User Says Thank You to Lieney For This Useful Post:
    MudRunnerTD (1st March 2013)
  5. #3
    330 Post(s)
    Quote Originally Posted by Lieney View Post
    I carry exactly the same!
  6. #4
    Ballarat, Vic
    174 Post(s)
    Sorry should have said. For the latter - 'self sufficient drive across central Australia' (or other remote parts).
  7. #5
    Thomastown, Melbourne
    6 Post(s)
    I think I have used a 22mm and maybe a 24???
  8. #6
    Ballarat, Vic
    174 Post(s)
    Thanks BA.
    Roll up, Roll up, any advances on 24mm?
    My socket set goes up to 32mm & ring spanners up to 27mm, but I'm in weight reduction mode & wanting to offload what I don't need. Would hate to need one a long way from anywhere & not have it though, expecially if I knew it was back home in the shed.
    I have a vague memory of reading a mention of a 27mm being required for some part of the suspension sometime back???
  9. #7
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Guaranteed the one you leave at home is the only one you will need!
    1999 GU 4500 dual fuel
    Il dado è tratto
  10. #8
    brisbane
    The largest would be on the radius arm or panhar rod?
  11. #9
    330 Post(s)
    Yep a 22mm is needed for the Tie Rod ends and a second 22mm or 7/8 would be handy. A big Shifter and a pair of big multi grips will take car of the rest i think. A Hub nut socket is handy too. the GU runs a 2 pin type and handy to have the right tool.
