Results 11 to 20 of 21
Thread: How to install an engine temperature sensor
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by Robo View Post
    Think your only option to use that.
    is locate a flat area you can lay the sensor and secure it.
    "it needs to be a position that gets hot like a normal sensor locations".
    Make a cover for probe and cover it for better transfer,
    using heat transfer paste between part and engine like used on computer parts would certainly help.
    and cover would resist wash off.
    you could try laying it along a hose and secure it and insulate.
    think you would not get a true reading.
    grind off the point, to prevent making a hole by accident.
    but bro think it would be easyer to simply buy either a elec or mech gauge with it's own sensor to suit your needs.
    Ebay cheap as chips.
    you'd be surprised also how cheap from local parts shop a complete unit.
    good luck
    Actually go to Jaycar , temp alarm to suit, and set to desired temp value.
    Sure you can get something in kit-form.
    Hi mate,
    That sensor unit is from Jaycar for $15. They don't stock it anymore. I asked them if they have any other unti that's more suitable for Automotive.
    They couldn't help me.
    I think laying it alone a metal pipe may work. But, I'm having trouble finding a metal coolant pipe in the RB30 engine. Laying the probe along a rubber pipe won't work, I think.
    I'm thinking to customize the probe with extra copper piece and attach it to the block.
    I will post pictures when or if I do it successfully.
    Hardcore
    central coast nsw
    have a look at temp device , KG 9140.
    the kit you mention they don't stock, can you get it back catalogue?.
    they do something called back catalogue.
    don't know how it works, back order old kits !.
    this type of approach along a pipe will give you an " rough idea " of the temp.
    my GTR employs such a device for measuring temp standard.
    part of the it's climate control system, not suitable for your device.
    Id be buying a VDO temp gauge and a sender that simply replaces a plug in say the inlet manifold.
    I know this can be done, as I've just done it .
    well, bar actually fitting them.
    I had a elec VDO gauge no sender,
    so I bought a sender to suit a plug and the gauges resistance.
    sender was $15 retail local bullseye , $13 on ebay + postage.
    going to pillar Mt it or above dash more so in line of sight than cluster.
    pillar & dash Mts start around $20 ebay inc del.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  4. #13
    Hardcore
    central coast nsw
    Can you find out the resistance range of the sensor you have?.
    Maybe able to adapt a conventional type temp sender,
    replace this hard to mount one that came with the unit as standard.
    as they come in a varying range of resistances and thread sizes, who knows you may get lucky !.
    "VDO have range values for each sender in their catalogue".
  5. #14
    Beginner Tanker's Avatar
    Feb 2013
    Chita, Siberia, RUS.
    What's wrong with installing the sensor in the upper radiator hose? By thermostat constantly going to a small stream. I have done so, everything works fine. I can upload pictures.
  6. #15
    Expert Petit caillou's Avatar
    Jul 2012
    FRANCE
    hello mate,
    If you have pictures of your different mounting thank you for the post, I'm interested in this topic.
    Best regards
    Petit caillou.
  7. #16
    Feb 2013
    Hi
    I have a temperature sensor Taiwan firm) Auto gauge. Good price and quality.
    Photos will be tomorrow.
  8. #17
    Feb 2013
    Power supply comes from the cigarette lighter fuse. The sensor only works when the ignition is on.
    Is embedded in the upper hose adapter to connect the sensor.
    The adapter connects to the body. The signal wire goes to the device.
  9. #18
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Has anyone tried this type?
    http://www.ebay.com.au/itm/130865025...84.m1423.l2661
    Sensor does not interfere with the coolant so no leak issues, but it would take time to read changes in temperature waiting for the mass of the engine block to heat or cool.
    Macca
  10. #19
    43 Post(s)
    Re: How to install an engine temperature sensor
    Looks the goods, but what's wrong with the stock temp setup? It runs from the coolent so imo the best reading you can get..
    Owner of
    Westy's Accessories
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Quote Originally Posted by Westy's Accessories View Post
    Owner of
    Westy's Accessories
    Agree with you there, the guage fluctuates a bit under load as in a long climb mainly on road and I'm curious to what the temp actually is and should I be concerned.
    Dont like graphic type guages, be better to have some numbers on it so it is clear what is happening.
    Macca
