20th February 2013, 04:17 PM
20th February 2013 04:17 PM
20th February 2013, 04:27 PM
Remove a spray/clean your MAF sensor.or replace check your TPS if maf is good
Do any errors show up ????????????? No boost?? all vacuum hoses on.
Just throwing it all out there, I call it networking lol
Check all fittings under engine cowl
chrysler (20th February 2013)
20th February 2013, 04:40 PM
it`s 41.4 outthere ATM the maf is blank ,white g/y,g/y,pink,black guess i will go back down the shed an check vac hoses an TPS???
20th February 2013, 04:43 PM
The Following User Says Thank You to 93patrol For This Useful Post:
20th February 2013, 05:06 PM
looks like maf does not seal properly ?? it has a rubber gasket.. and where might i find the tps thankyou in advance
20th February 2013, 06:20 PM
TPS will be under your right foot.....
Mic
20th February 2013, 06:21 PM
Chrysler, It looks like you are up for a new MAF as yours isn't sealing up properly, and this might resolve some of your problems.
20th February 2013, 06:31 PM
ty guys think i might try some stiky stuff in a tube ..lol... to seal it .as for the tps yep i found that ..some one didnt tell me not to remove the three nuts ...end up with spring an plastic bits flyin .lol all back together so will let you know how i get on
cheers Rob
