Results 1 to 7 of 7
Thread: ARB commercial bullbar + Alloy Hawse
    174 Post(s)
    Does anyone have the above combination? What Hawse did you fit? Any issues?
    Got a Marks adaptor hawse fairlead sitting here doing nothing
    they all fit as they are designed forthe standard bolt pattern
    Cuppa (16th February 2013)
    174 Post(s)
    PM sent thanks TD
    brisbane
    The only other thing I noticed when replacing mine was some have an offset for the bolts, can't say I've ever seen them being used so not sure if its needed for a high mount or diffrent bar
    We put a roped winch on my brother in laws GQ last weekend. Put the alloy hawse in the standard ARB bulbar and it was so far down it looked ridiculous. He got an offset hawse and is much better.
    174 Post(s)
    Can anyone tell from the attached pics whether I'd need a 'standard' or offset hawse?
    Or can I only tell by removing the rollers first? To remove the rollers is it just a matter of undoing the two bolts , one on either side, or are there other hidden ones anywhere?
    ARB steel Bullbar (are they essentially the same design for all vehicles?)
