15th February 2013, 09:47 PM
winch power cable
hi all
thourght id get seen more in this thread to get an answer
im after winch power cable lengths of 1m+ or custom made cables
not keen on paying $30 per mtr from bursons
also does anyone know if power2winch are still around ive tryed to email them and it failed
15th February 2013 09:47 PM
15th February 2013, 09:50 PM
The 747
winch power cable
Go to your nearest electrical wholesaler... Ask for welding flex in whatever size you want. Buy a crimp lug to suit and they will probably crimp it for you too. Where abouts are you located?
15th February 2013, 10:04 PM
located in tullamarine
what size / thickness do i need for 12v winch
15th February 2013, 10:07 PM
The 747
15th February 2013, 10:10 PM
15th February 2013, 10:27 PM
Hardcore
X2 on what winnie said about weld cable, its good stuff, but i think he must mean 15mm not 25mm ?
Get it soldered as well as crimped, easy job for a auto lec
The Following User Says Thank You to 04OFF For This Useful Post:
threedogs (16th February 2013)
16th February 2013, 06:18 AM
The 747
Re: winch power cable
25mm is what most winches come with standard. That being said 16mm would probably do the job no worries.
16th February 2013, 06:57 AM
Mudnut if you get stuck PM Im over TJM coburg this morning. can do there heaps cheaper too
If doing yourelf don't forget to finish the job with some heat shrink sleeving
