14th February 2013, 06:14 PM
Patrol Guru
holes or not in dash?
I have need to mount the hand piece for my uhf in another spot now and would like to know if anyone has done it without screwing into the dash. Are there other ways to hold it in position?
GQ Snorkle Lockers front n rear
14th February 2013 06:14 PM
14th February 2013, 06:16 PM
Really good double sided tape.... I just drill !!!
Double sided no matter how good on hot days gives up........
I'm tired!!!!!
14th February 2013, 06:28 PM
3M have a pressure sensitive tape thats awesome no idea where to get it would be pricey.
or sticky back Velcro
Where have all you GQ freaks yes freaks put your UHF mic
14th February 2013, 06:49 PM
CERTIFIABLY INSANE
Cable tied to the Jesus bar....
Tip tip tip......tap tap tap....
1997 GQ Patrol RX, TB42E. Mods: OME 2" lift, 33" BFG KM2'S, ARB winch bar & reconditioned X9 Superwinch, IPF 900 spotties HID conversion, ARB side steps and scrub bars, Kaymar rear step & spare wheel carrier & jerry holder, Rear 55W LED worklight, Safari Snorkel, 147L LRA tank, Extended diff breathers, dual batteries, GME UHF, Home built drawer and fridge slide, ARB 60L fridge.
14th February 2013, 06:54 PM
Dribble Master
Re: holes or not in dash?
I just use the heavy duty sticky backed Velcro for uneven surfaces from bunnings. It works well but do have to change the side that sticks onto the dash every couple of months because of the heat over here.
Don't stroke it, TAP it!!!!.....
14th February 2013, 06:55 PM
Patrol Guru
threedogs
the mic and body are tucked under the dash, very small unit with controls on the handset,
reguards FREAK ha ha
The Following User Says Thank You to 89gqpatrol4x4 For This Useful Post:
threedogs (14th February 2013)
14th February 2013, 07:30 PM
Rotaredom
I'm against drilling holes in the dash as I think if you go to sell the vehicle with holes in the dash then the resale value won't be as good as one without holes. Unless you intend to leave the UHF in there if you sell.
Find somewhere that has a bolt / screw hole already there and then make up a metal bracket that will hold the hand piece
14th February 2013, 07:45 PM
For starters I suppose it depends where you've mounted the head unit and where the hand held bit will reach
FanTapstic!
Hello from Under Down Under!
14th February 2013, 08:36 PM
Dribble Master
mines stuck to the top of the dash with said velcro lol........................ but saying that the previous owner managed to drill a couple of shoddy holes into the top which are next to useless
14th February 2013, 09:43 PM
Legendary
I have drilled my holes into a removable insert piece, like the Space for the Factory Diff Lock Switch.
For one, it doesn't look as bad when you come to sell it, and two, it should be cheap enough to buy the switch blank or pick one up from the wreckers.
Mic
