Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 82
Thread: My Camper Trailer Build Thread
  1. #21
    Thanks mate, So am I. I can't wait to get it all trimmed up inside and finished! Still gotta put a handle on the door, some sort of latch/locking system, I was thinking just a simple barrel style latch, gotta wire up inside with some lighting, was thinking LED strip lights and a couple of 12v ciggie plugs. Probably another few days, it will be done, I was hoping by the end of weekend and it'll b finished.
    Tappin
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    Trying it out at Easter?
    [SIGPIC]
  4. #23
    Maybe, was gonna do the winery thing that weekend. Was probably gonna use it the week after. Just wont have any time to work on it that weekend.
    Tappin
  5. The Following User Says Thank You to rusty_nail For This Useful Post:
    GUtsy ute (21st March 2013)
  6. #24
    43 Post(s)
    Re: My Camper Trailer Build Thread
    Don't forget the usb power outputs for charging phones, GPS etc..
    Looking tops though. I'm with td, polystyrene for insulation. See if you can find a supplier to cut it to size for you.
    What's the inside going to be lined with?
    Owner of
    Westy's Accessories
    Quote Originally Posted by Westy's Accessories View Post
    Owner of
    Westy's Accessories
    Thanks I forgot about them, I reckon I'll need about halfer dozen of those bloody things.
    Polystyrene will be the way to go, I think I might be able to get it at a craft shop of Clark rubber.
    I'm just gonna get the stuff they put on caravan walls, thin pre-finished on one side. I think camec or a camping store might be the go there.
    Tappin
  8. #26
    There is some 10mm stuff you see on new house frames, maybe a member will know the correct name.
    it's about 10mm and silver foil one side and blue on the other, cheap as chips, don't go to clarkes, cost
    a fortune IMO. Looking great BTW
  9. The Following User Says Thank You to threedogs For This Useful Post:
    rusty_nail (21st March 2013)
  10. #27
    43 Post(s)
    X2 with td about Clarke rubber... Rip offs .
    Are you thinking of the foam core board td?
    Owner of
    Westy's Accessories
  11. The Following User Says Thank You to BigRAWesty For This Useful Post:
  12. #28
    Cool it would be great to know a better alternative
    Tappin
  13. #29
    43 Post(s)
    I do know you can get sheets of colour bond with foam sandwiched between them. Around 5mm thick.
    Owner of
    Westy's Accessories
    I just used those "T" handles with key lock in the centre, never ever used them , but it was lockable.
    You may find the fancy flush ones use a bit of room. but you know KIS. Get some gas struts as well .
    Now you need a sky light or clear windows with fly wire sliding
