Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Central locking not working Patrol 2009 ST
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by ozputu View Post
    pulled the passangers side kick pannal off nothing but plugs and lots of wires, took the glove box out and there is a big box made by siemans, when you push the centralm locking button on the drivers door you hear a faint click from behind the centre consol. all fuses under the bonnet are ok.
    Thanks so far for all the advise
    Here is a picture of mine. On the left hand side you can see a blue relay, there is one circuit breaker below the relay (you can just see it in the photo) and one circuit breaker above the relay.
    I think the central locking one is the one on the bottom but check both.
    My vehicle is an earlier mode but I'm pretty sure they are still mounted in the same place.
  2. The Following User Says Thank You to Yendor For This Useful Post:
    ozputu (12th February 2013)
    Beginner ozputu's Avatar
    Feb 2013
    Port Kennedy WA
    Thanks Yendor, will have to check that when I get back home again, according to a auto sparky and the relay/control unit is faulty, awaiting a price on a new one. This relay is just to the left of the stereo.
    Will update when I get home and more info.
    Thanks to all for your advise
    Life is as good as you make it
  5. #13
    Oct 2019
    Hi my 2009 Patrol ST has lost its central locking, it wont lock with the button on the drivers door, it won't lock with the key (only the door that you use the key in), wont lock with the remote. I can hear a faint click some where under the dash when I push the central locking button but no doors activate, cannot find a fuse anywhere that has blown, (unless there is a hidden one that I don't know of). Has anybody else had this problem, oh and it happenned suddenly when we were camping, morning it worked tried again in the afternoon and nothing, thought I had a flat battery but it started straight up.
    I had the same issue with my remote.
    I solved the problem by using the correct battery.
    The battery that Nissan uses is thinner (CR 1620) than the similar sized one I bought at Coles (CR 1632).
    The thicker battery causes the contact between the battery cradle and the circuit board to fail.
