7th February 2013, 04:06 AM
Trailing Arm bushing
Hi fellows. I know that my trailing arm bushes need to be changed as I have the usual rear steer symptoms plus I did have my mechanic check them out, However would this cause a difference of 2 inches in the back between one side and the other? Also would this cause the vehicle to sway with a slight wind at speed (feels like from the back)?
7th February 2013 04:06 AM
7th February 2013, 07:42 AM
Re: Trailing Arm bushing
I can't see how the bush can affect the ride height, that sounds like a spring collapse...
But I'd say they are your sway issue, die to the joints being loose...
Owner of
Westy's Accessories
7th February 2013, 07:46 AM
Westy's Accessories
Owner of
Westy's Accessories
Thanks for the reply. How do you know if a spring has collapsed?
7th February 2013, 10:35 AM
Your ride height.. as one side has dropped a large amount I'd say its stuffed...
Given you don't have 100kg of lead of something in that corner...
Owner of
Westy's Accessories
