Good try Avo, it is in Kakadu & not too far from Mirrai. See if you or anyone can pick the lookout, but if not I’ll give it to you as you are pretty close.
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
Nourlangie lookout, I nearly picked this one first..lol...as soon as I seen it I remembered that view, we went up there a few years ago and spent a bit of time touring that area.
And yep it is the lookout at Nourlangie, in Kakadu NP. The lookout itself is called Nawurlandja Lookout but no doubt Avo’s picked it.
Your turn Avo.
