5th February 2013, 06:40 PM
heavy front end vibration whilst driving
Hi all,
Hoping you may be able to asist me with a problem i have had.
I bought a Ti Patrol in 2005 and ever since have had a random shaking while driving. It used to only happen every now and then ............. and nissan service agent on the gold coast could never find a problem.
The last couple of years it has gotten worse and now when it happens i have to stop the car or turn sharply to get it to stop. I have taken it to over five different mechanics and all say there is no problem.
Tried wheel alignment/tyre balancing.......... had suspension checked etc.
I note it appears worse when in the rain and or going down hill.
Has anybody had this before?
Appreciate any assistance on this one.
Slyder
5th February 2013 06:40 PM
5th February 2013, 07:05 PM
Check your wheel nuts first , they have a habit of coming loose.
is it at 80-90 k when it starts to shake??
You may want to pop over to intro section first, just something the forum asks of all of us.
plus you'll get a better response as well. now I'm thinking engine mount
5th February 2013, 07:49 PM
thanks threedogs
generally it does seem to occur at that 80-90km interval. but will occur lower speed if going down hill or if in the rain.
I had some time ago checked the wheel nuts......... it did not seem to make a difference.............. i had a mate whose wheel came off his patrol.
5th February 2013, 08:11 PM
Next time its up on a hoist go over all the bushes etc with a very large screw driver
Check engine ,trans/gearbox mounts as well. Check wheel bearings too
6th February 2013, 06:11 PM
thanks will do.
im looking for a good 4x4 mechanic local.... you know anybody worth there salt?
6th February 2013, 10:38 PM
replace the steering dampner, these take a period to fail, replaced mine with a quality aftermarket unit & fixed the same issue, never been back in 2 years, still drives nice now
2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
7th February 2013, 01:03 PM
Hi Slyder, your not alone in this, mine does the same around 80 -90 kms thats when you use two hands on the wheel .....lol , then you do 100 and it go's away regard Alex
7th February 2013, 01:39 PM
Had a similar problem in mine. It ended up being the Radius arm bushes being flogged out. That being said I still get a small amount of wobble/feedback between 80-90 once in a while. Am going to replace my steering damper soon as i think this may help soften the shakes. Good luck with it mate.
Don't know if you want to travel up to Capalaba to get to a good mechanic but I know BigRig and a couple of others all go to the one bloke there.
SPEED METAL NEVER WENT AWAY>>>>> ONLY OUR HEARING DID!!!
11th February 2013, 12:58 AM
I have had the power steering looked at? ...... would they have picked up the dampner issue? ill get it looked at this week.............
thanks heaps guys............. this is the first time ive had anybody help me with it.......nissan dealer mechs (von bigra) were useless............. been there about six times and no help!!
11th February 2013, 01:05 AM
An they probably wouldn't as it looks like a shock absorber put in the wrong spot so they more than likely wouldn't look at you can see it from the front of the car looking underneath
Just tap it in just tappy tappy tappy
